Author Topic: 67 water pump mounting bolts  (Read 3594 times)
1967RS/SS
« on: April 25, 2023, 12:21:54 AM »
Anyone have pics or can give direction on the correct water pump bolts and their locations for a 67 350 (L48)?  Some parts vendors show 2 studs but the 4 I removed had bolts (no studs).  Had to drill a couple out because they were frozen in the block and the heads were rounded off.
I went through the AIM but couldn’t find a diagram.
1967 RS/SS L-48
Van Nuys 01C
Joseph
Re: 67 water pump mounting bolts
« Reply #1 on: April 25, 2023, 01:07:50 AM »
The Water pump is installed by the Engine plant and the best views of the hardware associated with the Water pump can be assumed  by looking at the AIR pump and Alternator sections, that give clues to Stud style hardware used.
manyc
    • Relic Recyclery
« Reply #2 on: May 22, 2023, 04:42:17 PM »
Obsessed amature restorer. Cars include 1969 Firebird 350 Conv, 1967 Camaro RS/SS conv Blue-Topper, several limited edition 1969 Mustangs, Panther Pink 1970 Challenger, 1963 Jaguar E-Type.
"If I can't fix it, I will fix it so no one can!"
Petes L48
« Reply #3 on: May 23, 2023, 01:16:08 AM »
Also if a factory AC car, check out UPC C60 in the AIM.  The compressor bracket goes on top of the pump on the passenger side, and likely requires two longer bolts.  The assembly plant would remove the two from the engine plant, when installing the bracket and the required longer bolts.  I don't think anything affected the driver side bolts.
1967RS/SS
« Reply #4 on: May 25, 2023, 04:47:27 AM »
Thanks guys.  I ended up getting the correct studs online.
1967 RS/SS L-48
Van Nuys 01C
Joseph
CantRepeat
« Reply #5 on: May 26, 2023, 08:32:19 AM »
Which set and who from?
-Tim
