Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
69 Pulling To The Right
« previous
next »
Print
Pages: [
1
Author
Topic: 69 Pulling To The Right (Read 3898 times)
Bigfish45
Member
on:
April 24, 2023, 10:57:43 PM »
Do any of you experienced front alignment guys see anything in this alignment setting on my 69 big block Camaro that would make it pull to the right? All front suspension components are OEM style and complete front end rebuild has 9000 miles on it. Any advice or opinions would be appreciated. Thanks
Tweet
Logged
ric1969
Member
Re: 69 Pulling To The Right
Reply #1 on:
April 25, 2023, 02:14:58 AM »
The setting you have is ok, try swap the tires right to left , left to right or another set of tires.
Logged
usa1ti
Member
Reply #2 on:
April 25, 2023, 12:16:05 PM »
Disc or Drum? If disc it possibly is a sticking caliper. Ive had several do that in the past. I even recently had my F350 do it with 2 new calipers. Had to replace the right side 2X.
Logged
Todd, East TN
camaronut
Hero Member
Reply #3 on:
April 25, 2023, 03:05:28 PM »
Maybe check the air pressure on all your tires.
Logged
David K
Hero Member
Dr. Longblock
Reply #4 on:
April 25, 2023, 06:20:21 PM »
We’re assuming tire pressure is equal and correct?
What type of tires?
Does it pull without braking?
What speed is is most noticeable?
Is it getting worse?
Have you inspected all of the front end components?
Do the tires indicate irregular wear?
Logged
Bigfish45
Member
Reply #5 on:
April 26, 2023, 12:21:53 AM »
I swapped the passenger side tire over to the driver side and driver side tire over to the passenger side. That corrected the minor pulling to the right issue. 😁
Logged
Print
Pages: [
1
« previous
next »
Maintenance
