Author Topic: Original stamp or re stamp  (Read 5186 times)
Torsionbar
« on: April 13, 2023, 01:11:17 PM »
Hello
I'm looking at a block to replace a CE block I have that spit the wrist pin out and destroyed a bore.
Found this block and I'm curious if some experts can give me their opinion on the DZ stamp. To me it looks legit and you can see the partial vin next to it but the deck surface looks pretty rough.
Thanks for any input
« Last Edit: April 13, 2023, 02:00:27 PM by Torsionbar »
Re: Original stamp or re stamp
« Reply #1 on: April 13, 2023, 01:12:57 PM »
I don't see a DZ stamp. Just a picture of the casting date "L 12 8" (December 12th, 1968)
Torsionbar
« Reply #2 on: April 13, 2023, 01:57:53 PM »
Oops
I tried to upload 3 pictures.
I'll see if I can upload the correct picture.
Thanks for pointing that out.
« Reply #3 on: April 13, 2023, 02:07:10 PM »
Looks good to me. Can you make out the partial VIN next to the suffix? Looks like 9N56?????
Torsionbar
« Reply #4 on: April 13, 2023, 02:09:35 PM »
 I will be going to have a look at it soon.
Unfortunately that's the only pictures I got from the seller.
David K
  • Dr. Longblock
« Reply #5 on: April 13, 2023, 02:37:21 PM »
Ed, I'm curious how the DZ can be so easily seen but not the partial.
« Reply #6 on: April 13, 2023, 02:46:52 PM »
Assembly date stamped at engine assembly plant; vin at car plant.  2 different people stamping and one was heavier handed vs the other.  Plus it appears the vin was attempted to have been removed at some point.
David K
  • Dr. Longblock
« Reply #7 on: April 13, 2023, 04:18:23 PM »
Call me pessimistic, but i see what appears to be a 2nd set of numbers.....or is it my imagination? I've had Lasik so I see OK.
boomer632
« Reply #8 on: April 13, 2023, 04:52:32 PM »
I always thought that having broach marks on the pad that run perpendicular to the cylinder bores was one of a few good indicators of a legit stamp. It looks to me like someone ran a flat disk on pad or had block decked then re stamped numbers. Broach lines should be straight, not circular. Thats just my observation tho.
06A X66 711 57 57 L78 M22 BU
« Reply #9 on: April 13, 2023, 05:54:45 PM »
It's an original engine stamp.
« Reply #10 on: April 13, 2023, 06:11:51 PM »
Quote
Usually. Broach marks are now being faked and with most you can tell, but there are some really good ones out there that are much harder to detect so don't use "just" the broach marks to determine a factory pad.
« Reply #11 on: April 13, 2023, 07:44:25 PM »
I know for a fact some of heavy hitters selling parts have been restamping for decades and stealing. Some guys think they have legit Chevys but they are not.
« Reply #12 on: April 13, 2023, 08:01:49 PM »
That pad has been mistreated - gotta see through that...
David K
  • Dr. Longblock
« Reply #13 on: April 13, 2023, 09:18:20 PM »
The 2nd set I'm referring to is the area where the VIN is.
David K
  • Dr. Longblock
« Reply #14 on: April 14, 2023, 12:49:01 AM »
Marked where I see numbers…..
