Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Maintenance
Coil and battery voltage measurements to determine if a resistor is installed
« previous
next »
Print
Pages: [
1
Author
Topic: Coil and battery voltage measurements to determine if a resistor is installed (Read 4645 times)
JGraft
Member
on:
April 06, 2023, 06:20:07 PM »
Hi CRG experts,
Voltage measurement at the coil is 12.52 volts, voltage measurement at the battery is 12.63 volts, a difference of 0.11 volts.
Does this mean this vehicle does or does not have a resistor in the ignition system?
Thx,
Jeff
Tweet
Logged
Everett#2390
Member
^Bess
Re: Coil and battery voltage measurements to determine if a resistor is installed
Reply #1 on:
April 09, 2023, 06:37:45 PM »
The wire from the firewall connector to ign coil is a resistive wire - cloth covered by GM design.
Logged
A flashlight is a case for dead batteries.
CRG Coordinator
Reply #2 on:
April 13, 2023, 05:41:38 AM »
It would appear to not have a resistor.
Logged
Print
Pages: [
1
« previous
next »
Maintenance
