Author Topic: Coil and battery voltage measurements to determine if a resistor is installed  (Read 4658 times)
JGraft
Hi CRG experts,
Voltage measurement at the coil is 12.52 volts, voltage measurement at the battery is 12.63 volts, a difference of 0.11 volts.
Does this mean this vehicle does or does not have a resistor in the ignition system?
Thx,
Jeff
Everett#2390
  • ^Bess
The wire from the firewall connector to ign coil is a resistive wire - cloth covered by GM design.
It would appear to not have a resistor.
