Author Topic: Jerry the intake looks great!  (Read 14842 times)
Ron C.
« on: April 28, 2007, 09:09:14 PM »
Jerry, Thanks a lot for the nice job you did on my 67 intake, it really makes the engine look good. Cant wait to get it in the car! ;D
Re: Jerry the intake looks great!
« Reply #1 on: April 28, 2007, 10:56:50 PM »
Ron -
Your engine looks great!  I was just wondering if the engine lifts brackets are original?  I thought only the big blocks got them in '67.   ???
Ron C.
« Reply #2 on: April 28, 2007, 11:06:16 PM »
Yes your correct! im useing them only to install motor then they come off! Supposedly no lift brackets were left on the Z motors in 67.Please correct me if im wrong ;D
Jonesy
  • 1969 Camaro z28
« Reply #3 on: April 28, 2007, 11:23:53 PM »
No engine brackets is correct. Engine looks great.
1969 Z28 Azure Turquoise
« Reply #4 on: April 28, 2007, 11:42:46 PM »
Did the '68 302s get engine lift brackets?
Ron C.
« Reply #5 on: April 28, 2007, 11:46:41 PM »
I dont think so,not untill 69 I think
Jerry@CHP
« Reply #6 on: April 29, 2007, 01:51:02 PM »
1968 engines did receive engine lift hooks.
JM
sebastien
« Reply #7 on: April 29, 2007, 06:38:21 PM »
all 68 engines? or only 302?
Sebastien 68  327 rag top
Jerry@CHP
« Reply #8 on: April 30, 2007, 01:22:46 AM »
All engines.
JM
AFONEFE
  • Daily driver in background
« Reply #9 on: April 30, 2007, 01:38:05 AM »
NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  :D
69 Z/28 X-77
"CHP, this is Chris can I help you?"
« Reply #10 on: April 30, 2007, 04:36:09 AM »
JM
Ugh!!  Mine are missing.  Jerry, did all the small blocks use the same ones?  Are the ones for 1968 engines the same as any other years?  Do they have any special stampings or (insert here) on them?  Thanks in advance.
« Reply #11 on: May 06, 2007, 02:49:41 AM »
JM
Anybody?
Jerry@CHP
« Reply #12 on: May 06, 2007, 01:07:31 PM »
All 68 and 69 small blocks use the same engine lift hooks.  One hole in each hook.  What I don't understand is how everyone is mis-led using the 1970s double hole front hook.  Every time I go out on the road, most small block cars that I inspect have that double hole lift hook.  Many are buying the incorrect stuff or getting bad information.
Jerry
« Reply #13 on: May 07, 2007, 04:24:30 AM »
Thanks Jerry!  I wanted to be sure before I start my hunt.
Flowjoe
« Reply #14 on: May 23, 2007, 07:17:37 AM »
Jerry
when you say "double hole" are you referring to the large hole through which the hook passes or the small hole through which the intake manifold bolt passes to secure the bracket to the engine?
