Here is the description of the front springs from the manual - Springs should be a natural finish, blued or dark phosphate. Paint is not acceptable. The sway bar is painted semi-gloss black. When doing the manual, we tried to use photos of what would be correct. The 68 Z28 used was restored nearly 30 years ago. It was used to show the original body panels with spot welds ( especially rear wheel wells), original interior, and original engine and components. Back then, bare steel painted springs were acceptable. The photo above was used to show the original tie rod adjuster and hardware. Repos are different Could not avoid getting the spring in the background. Nor could it readily be taken out and have a correct finish put on. The sway bar links in the photos have the correct finish. Please look at what the photos are being used for with the captions. Not perfect but go with the descriptions
