Author Topic: Crossram air Filters air flows  (Read 4956 times)
WaltZ
« on: January 19, 2023, 04:52:40 PM »
is there an after-market Crossram inexpensive 2.5" tall air filter available.
does not need to be show quality or replicated.
I have a couple of the 1.75" tall $25.00 filters but unsure about inadequate air flow when I get on it.
or, maybe I'm ok with 1.75" talls
Any thoughts will be appreciated.
Thanks in Advance,
Walt
crossboss
  • ^ New engine project
Re: Crossram air Filters air flows
« Reply #2 on: January 19, 2023, 06:01:18 PM »
I believe the 'Cobra' oval air cleaners are the same. That said, it should be readily available.
1968 Olds 442 W-30
Pacecar
« Reply #3 on: January 19, 2023, 06:07:28 PM »
I have used the Cobra air filters when running and driving. Switched to OEM when shown
David K
  • Dr. Longblock
« Reply #4 on: January 20, 2023, 02:13:26 AM »
To understand this question,….you have an air filter but have never used it and are questioning if it will prevent the engine from receiving enough air under heavy load?
MO
« Reply #5 on: January 20, 2023, 06:25:57 AM »
I think the answer is no. There is no cheap "quality" air filter for that application that I know of. I like the K&N filter though. It has a higher upfront cost, but is reusable; literally forever. Meaning you'll never have to buy another filter. And it likely breathes better than any paper filter available. Not stock looking though if that's what you're after.
WaltZ
« Reply #6 on: January 20, 2023, 02:47:05 PM »
thanks, would you happen to know the K&N number.
much appreciated.
MO
« Reply #7 on: January 21, 2023, 06:05:30 AM »
much appreciated.
E-3515. Click on the posted link in the 1st reply above by Charley.
