Author Topic: Power Steering Pump Adjustment Bracket/Motor Mount  (Read 1864 times)
edmac786
« on: January 18, 2023, 11:53:21 PM »
I have a 69 Cameron w/a 68 327 engine. I found that my motor mounts were bad. When replacing the left mount I discovered that the adjustment bracket for power steering pump was installed underneath the bracket (between the block and the mount) in the front two holes and a washer in the back hole to make up the space. Any idea on what the proper power steering pump brackets I need for a correct installation?
