Author Topic: 69 SS Axle Codes  (Read 3109 times)
boomer632
69 SS Axle Codes
« on: January 17, 2023, 03:29:14 PM »
Car is a 69 X66 with L78 motor and M22 with 12 bolt posi
Axle is stamped BU 1126 G1
                                 E
Which translates to 3.73 assembled 11/26 1968 Detroit Gear 1st shift with Eaton Posi
Casting date code on housing is K 22 8 which is Nov 11 1968
Casting Code on housing is 3894860NF
My trim tag is 06A with NCRS shipping date of 6/16/69
Is it safe to assume my axle is not original due to the lapse in time from body date and axle build dates?
Thanks in advance.
06A X66 711 57 57 L78 M22 BU
Re: 69 SS Axle Codes
« Reply #1 on: January 17, 2023, 03:30:51 PM »
I would not assume that.  Keep it and look for a date closer as you never know your paperwork might show up at some point.
« Reply #2 on: January 17, 2023, 03:58:15 PM »
I'm 99.999 percent sure it's not original. All the BU axles we have in the database during the 06A time frame for Norwood (approx 35) are dated mid May to early June, 1969.
« Last Edit: January 17, 2023, 05:36:00 PM by bertfam »
Kelley W King
« Reply #3 on: January 17, 2023, 04:13:38 PM »
My 69 L78 has a 12 bolt dated November 12th 1968. The car is a 12A Norwood car. The rear is a BT 3:55 posi.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #4 on: January 17, 2023, 04:38:42 PM »
Casting date K 22 8 would be November 22, 1968.
