Author Topic: AIR CLEANER SERVICE DECAL  (Read 5013 times)
DAVID CHAMBERS
« on: January 16, 2023, 08:28:03 PM »
What is the final verdict on the correct air cleaner service decal for a 1969 350/300 SS manual Oct. 68 built?
Black CO 6484584? Thanks
KevinW
Re: AIR CLEANER SERVICE DECAL
« Reply #1 on: January 16, 2023, 09:08:10 PM »
I'm curious too.  I don't have an SS in that build date, but I do have a 2bbl 327 with that build date.  There are a bunch of things that are 68 leaning on the car, but the air cleaner was missing.  My opinion for my 2bbl is the older black gold label (which is not reproduced), so I had a one off done by Don L.
DAVID CHAMBERS
« Reply #2 on: January 16, 2023, 09:43:08 PM »
Thanks Kevin. I will check with Don.
DAVID CHAMBERS
« Reply #3 on: January 17, 2023, 12:56:10 PM »
Anyone else have answers? Thanks
Petes L48
« Reply #4 on: January 17, 2023, 03:56:25 PM »
Here's the Feb 69 P&A manual page.  The 4584 cleaner assembly appears to be for auto trans.
http://gmpartswiki.com/getbigpage?pageid=75055
DAVID CHAMBERS
« Reply #5 on: January 17, 2023, 08:54:04 PM »
Thank you Pete, looks like it will be the 6484583. Now not sure if it is CO or CN? This is a great help sir.
DAVID CHAMBERS
« Reply #6 on: January 18, 2023, 12:57:59 AM »
PETE WOULD YOU HAVE THE PAGE BEFORE THIS THAT SHOWS THE 1968 350,MINE IS A 68 MADE SS. THANKS
« Reply #7 on: January 18, 2023, 01:23:51 AM »
Quote
HERE you go (Group 3.402), but a 1969 Camaro assembled in 1968 would still be a 1969 model.
DAVID CHAMBERS
« Reply #8 on: January 18, 2023, 03:41:59 PM »
Thanks Ed, looks like the correct number.6484583. I was told the 69 cars made in 68 had a black decal? Not sure what the 2 letters with the numbers are. Like CO or CN?
DAVID CHAMBERS
« Reply #9 on: January 18, 2023, 04:07:37 PM »
Could someone tell me the OE correct AC Delco air filter number? Thanks
Petes L48
« Reply #10 on: January 18, 2023, 06:45:56 PM »
No idea, but maybe the two letters are related to or same as the codes and footnotes shown in this chart:
http://gmpartswiki.com/getpage?pageid=49735
« Reply #11 on: January 18, 2023, 07:19:01 PM »
The part # needs to match the broadcast code.
L48 auto is CN.
The numbers and codes didn't change when they redesigned the label.
