Here are a few pics of the Muncie shifter levers when in neutral and reverse. When in neutral, the 1 - 2 and 3 - 4 side cover shift levers will be positioned straight up, and the reverse lever will be approximately vertical. In neutral, the shifter gate levers will be pointing approximately straight down, and all in line so that a neutral alignment pin can be inserted thru the shifter housing and a slot in all (3) gate levers. When shifted into reverse, the reverse gate level will point towards the rear as shown in the 3rd pic below.
