Author Topic: 69 Z28 oil pan, repop?  (Read 5289 times)
WaltZ
« on: October 26, 2022, 11:33:51 PM »
does anyone make a reproduction 69z28 oil pan with oe style rails and baffles.
thanks in advance,
Walt
BillOhio
    • photobucket
Re: 69 Z28 oil pan, repop?
« Reply #1 on: October 27, 2022, 01:40:56 AM »
I have a new gm one that was supposed to be for a 302 several years ago.  I will have to look but not sure the dipstick is on the same side
1968 RS 327 4 speed
MO
« Reply #2 on: October 27, 2022, 05:27:16 AM »
I doubt there is a reproduction oil pan that is identical to the original. Even GM replacements are not identical.
Stingr69
« Reply #3 on: October 27, 2022, 05:19:32 PM »
Bob Harris supposedly has the tooling to make the GM replacements.  Camaro Specialties in East Aurora NY.   You might look there.
BillOhio
    • photobucket
« Reply #4 on: October 31, 2022, 01:08:51 AM »
the part number on my gm pan is 00360450.  I did see some pictures online but not sure if they still have them.  I might have bought this 6 or 7 years ago
1968 RS 327 4 speed
« Reply #5 on: November 03, 2022, 02:02:54 AM »
Agree, I had a GM NOS service replacement purchased in 1979 and it was much different from original. Here u can see som differences.
https://www.camaros.net/threads/time-for-another-68-z-28-to-be-restored.182584/page-21#post-1654981
MO
« Reply #6 on: November 03, 2022, 05:12:02 AM »
Great example.
mgreenz
« Reply #7 on: November 03, 2022, 06:02:47 PM »
This listing states that the seller can add windage tray rails to their service replacement oil pan.
1968 - 1974 Camaro , Chevelle, Nova Reproduction of Original (Z/28 Pans Also) | eBay
If the regular production '69 Camaro small block oil pan is externally the same as the Z/28 pan could you not remove the baffle and install windage tray rails?
I understand that sheet metal work, welding, templates and patterns would be required but it seems like a doable project if the information was available.
The production '67 pans appear to be externally the same as the '67 Z-28 pans so this is what I intend to do for my '67 302 build. So far I've collected a couple of 3-step production pans and removed the baffle from one of them although the project is now waiting for me to develop metalwork/welding skills. I'd also like to obtain more detailed information on the rails to add to the photos I've saved. From the photos I've got, it appears that the '67-'69 windage tray rails (scrappers?) are very similar.
___
Terry
Stingr69
« Reply #8 on: November 03, 2022, 07:52:28 PM »
$275 to tack weld 2 strips of steel??? On top of the $200 for the pan???  I would take a swing at it with my MIG welder on a standard GM pan before paying that much.  Click the link below for a picture.
Original? no, but functional, yes.
https://momcp.com/product/1969-72-camaro-z28-302-350-nos-gm-small-block-chevy-oil-pan/
