Author Topic: Hood Insulation Pad Interference  (Read 2727 times)
Henry Cloutier
« on: October 22, 2022, 12:06:29 PM »
Hello All,
I've discovered the cowl induction rubber seal has a larger diameter than the cut-out in the insulation pad. Are there different cut-out sizes depending on application? I have no problem replacing the one currently installed, I just want to make sure I order the correct one.
Thanks and Best Regards,
Hank
Re: Hood Insulation Pad Interference
« Reply #1 on: October 22, 2022, 05:01:40 PM »
Unfortunately, That Entry Level Cheaper (Affordable) Generic under hood insulation is just that.
I believe there are two mfr. (versions) of the Molded flat hood insulation that have nicer features and better sizing. Which includes increase initial cost and shipping (Flat)
Then there is an opportunity to get the correct four hole plastic retainers also.
Henry Cloutier
« Reply #2 on: October 23, 2022, 11:09:16 AM »
Thanks for the info. I'll go shopping!
Best regards,
Hank
« Reply #3 on: October 23, 2022, 05:26:48 PM »
BDY-1224 & BDY-1225
Heartbeat City Camaro
