Author Topic: Stock Exhaust Manifold Removal - 69 SS 350  (Read 8465 times)
camaronut
« on: October 02, 2022, 04:49:23 PM »
Looking to remove my stock exhaust manifolds in my SS 350.. any pointers before I tackle this?  Looks like the passenger side is a breeze, but the drivers side looks a bit more of a pita.
Appreciate any real world experience on this…. thanks!!
Re: Stock Exhaust Manifold Removal - 69 SS 350
« Reply #1 on: October 02, 2022, 07:34:15 PM »
Piece of cake and self explanatory. Just unbolt what is required. Only been doing this 45 years. If you own a classic the simple things should be no problem.
camaronut
« Reply #2 on: October 02, 2022, 07:52:06 PM »
Looks a little dicey on the drivers side, didn’t know if I had to remove the temp sensor or not.  Then I’d have to empty the coolant. Just bs like that..
David K
  • Dr. Longblock
« Reply #3 on: October 02, 2022, 09:54:48 PM »
Depending on how long they have been on the engine means everything when it comes to removal. How long?
camaronut
« Reply #4 on: October 02, 2022, 10:15:43 PM »
Hey Dave!!! Maybe for 15 yrs or so.  It s/b easy- just wanted to know if there were any hiccups that could get in the way.
David K
  • Dr. Longblock
« Reply #5 on: October 08, 2022, 01:11:58 AM »
Sorry I didn’t see this reply sooner. Yes there are. The bolts could be seized in the head and could snap off if you hammer them with an impact gun. I typically apply a ton of  PB Blaster a few times and allow it to soak for a day. Always use a 6 point socket. Always. Slowly attempt to free them up. Feel free to PM me.
camaronut
« Reply #6 on: October 09, 2022, 11:48:44 AM »
I don’t think I’ll need an impact gun on this one… bolts are pretty clean - hell - the car goes nowhere.  But I’m pretty sure they’ll come out easy - at least I hope so.
David K
  • Dr. Longblock
« Reply #7 on: October 09, 2022, 03:39:31 PM »
Best to apply some free me up stuff. I actually loosen them up a little-each one-and then spray lube between the manifold and block to allow it to creep up the threads. Then if they’re tight I work them back and forth. But if they’re loose, I just take out the middles first. Use an air ratchet.
Going back in-I clean the threads on a wire wheel and apply anti seize on the threads. Use a torque wrench. Upload a picture or 2.
Looks like the passenger side is a breeze-Famous last words.
David K
  • Dr. Longblock
« Reply #8 on: October 20, 2022, 02:11:52 AM »
Well?
David K
  • Dr. Longblock
« Reply #9 on: November 04, 2022, 01:24:23 AM »
I guess they’re still in the engine.
camaronut
« Reply #10 on: November 05, 2022, 08:49:01 PM »
Good ol Covid  - stopped me in my tracks.  I was gonna do the swap this weekend but nope!!!  Maybe next week.
camaronut
« Reply #11 on: November 09, 2022, 07:14:03 PM »
Performed the swap - no problems  ---  Until I started the car and heard exhaust popping from the passenger side - middle-two exhaust where the manifold meets the head.  Pulled it off again, and I didn't notice (total stupidity on my part) that the exhaust manifold surface where it meets the head was not totally flat - iow, had rust pits and it wouldn't seal up real nice.  :(
Now what!....LOL!
David K
  • Dr. Longblock
« Reply #12 on: November 10, 2022, 01:58:16 AM »
You installed new gaskets?
camaronut
« Reply #13 on: November 10, 2022, 01:01:05 PM »
Never installed gaskets because GM never used them initially.  I could try that, but I'm just going to repaint / reinstall the one that I took off.  It's in good shape.
David K
  • Dr. Longblock
« Reply #14 on: November 11, 2022, 01:33:17 AM »
I installed them all the time because I did not want to do it twice.
