Author Topic: Air Cleaner spacer?  (Read 3435 times)
Henry Cloutier
Air Cleaner spacer?
« on: September 29, 2022, 12:15:19 AM »
Hi you all,
I'm confused... I went to replace the cowl induction seal and the lip to secure it was pointed the wrong direction. So I grabbed the AIM and figured out the Camaro Central guys had it inside out. I flipped it around and also noticed in the diagram there is a spacer between the air cleaner base and the flat flange where the seal is mounted. Is this spacer supposed to be on this car?
Thanks and best regards,
Hank
Re: Air Cleaner spacer?
« Reply #1 on: September 29, 2022, 01:23:39 AM »
302 and L48 350 used an extension between the air cleaner and flange. Each is unique to the application.
Big blocks did not use an extension.
Henry Cloutier
« Reply #2 on: September 29, 2022, 11:09:46 AM »
Makes perfect sense now. Thank you for the clarification! I'll get the correct one ordered.
Hank
camaronut
« Reply #3 on: October 13, 2022, 11:10:13 AM »
"I went to replace the cowl induction seal and the lip to secure it was pointed the wrong direction. So I grabbed the AIM and figured out the Camaro Central guys had it inside out. I flipped it around and also noticed in the diagram there is a spacer between the air cleaner base and the flat flange where the seal is mounted."
If I got a dime for every upside-down Cowl Induction seal I saw in the past 30 yrs, I'd be a millionaire.
