Author Topic: z28 intake  (Read 3668 times)
Richard 302
z28 intake
« on: September 19, 2022, 10:00:02 PM »
Is there a consensus about when the first 67 z28 rolled off the assembly line? I was digging through old parts today and came across a 610 intake.  When I turned it over to look at the bottom to see if the heat shield was there, I noticed it was dated 3-14-67.  Seems to me that's awful early for a z car.  Did they use these intakes on 327 engines also in 67?
Chuck-68-Cam
  • It is what it is
Re: z28 intake
« Reply #1 on: September 19, 2022, 10:24:31 PM »
Post #17.
http://www.camaros.org/forum/index.php?action=search2
Not sure if it is a consensus, but seems to be in the know.
Chuck
68 Camaro SST 350/TH400
Re: z28 intake
« Reply #2 on: September 19, 2022, 11:46:06 PM »
Yes, there is.... Many parts were made for 67 Z/28's prior to 3-14-67.
https://www.motortrend.com/features/first-1967-chevrolet-camaro-z-28-back-track-years-research-meticulous-restoration/
Richard 302
Re: z28 intake
« Reply #3 on: September 20, 2022, 02:22:16 AM »
Thanks for the links. Didn't know 67 z/28s' were available that early.
MO
Re: z28 intake
« Reply #4 on: September 20, 2022, 04:53:44 AM »
There are 16 known Z's built before 1/1/67. As stated, the first was built 12/29/66 and was the only one built that day. There were over one hundred Z's built (NOR LOS combined) by the end of March 67.
« Last Edit: September 20, 2022, 08:04:08 PM by william »
Richard 302
Re: z28 intake
« Reply #5 on: September 20, 2022, 08:04:42 PM »
So I assume these 610 intakes were also used on 66 and 67 327 L79 engines too?
Re: z28 intake
« Reply #6 on: September 20, 2022, 08:16:56 PM »
Quote
Nope. Just 67 and 68 Z28
mgreenz
Re: z28 intake
« Reply #7 on: September 21, 2022, 03:02:35 PM »
If your interested in 67-68 Z28s get a copy of the Fact Book. Lots of good information there including order/build dates for the first 25 1967 Z28s.
https://www.z28camaro.com/publications/
I know of 610 intakes dated 3.8.67 and 3.10.67. Perhaps production was ramping up at that time as the model year was approaching the final quarter.
___
Terry
