Author Topic: Engine Numbers  (Read 6077 times)
stovebolt_six
Engine Numbers
« on: April 24, 2007, 10:01:25 PM »
Okay fellas, I've found two more  engine numbers for you "numbers gurus" to decode if you would and they are as follows:
1)   FI228 YS
2)   VII23WA
Thanks in advance...Clint
Re: Engine Numbers
« Reply #1 on: April 24, 2007, 10:47:45 PM »
Clint -
Both are truck engines.  YS = 1966 or 1968 327 cid engine.  WA could be a 283, 307, or 350 cid engine depending on the block casting date.  If you know the block casting dates we can narrow it down for you.
Re: Engine Numbers
« Reply #2 on: April 24, 2007, 10:49:58 PM »
"YS" was used in Chevrolet Trucks from 1965 through 1969 in a few configurations:
1965 - 283/185
1966 - 1967 - 327/220
1968 - 327/240
1969 - 396/310
The "WA" was also used in Chevrolet Trucks from 1965-1969 in the following configurations:
1965 - 1967 - 283/175
1968 - 307/200
1969 - 350/255
You'll need to get the date code to see which engine yours is.
RAfbody
Re: Engine Numbers
« Reply #3 on: April 25, 2007, 02:50:22 PM »
I would have to think the F1228YS would be the 65  or 66 engine since the assembly plant code is "F" instead of "V".  I don't remember the date the flint engine plant changed from F to V but I know it had changed by 1967.
Russ
Re: Engine Numbers
« Reply #4 on: April 25, 2007, 04:32:30 PM »
The Flint V-8 prefix changed from "F" to "V" at the beginning of the 1967 model year.
