Author Topic: Speedometer Cable Codes  (Read 9854 times)
Re: Speedometer Cable Codes
« Reply #15 on: October 22, 2022, 04:15:16 AM »
Date matters, auto vs man trans matters, speedo adapter probably matters. But the usage sometimes changes for unknown (to me) reasons.
Here's what I have for 69 (with a caveat for limited data):
CF (May & later) - V8 auto, Z28, BB auto & man
CT (pre May) - V8 auto, Z28, BB man
CV  (pre May) - L6 & low-po auto
CW - L48/M20, BB auto & man
CX - L65 & L14 man
CY - L65 man
CH is a full-size code. And I've not seen a CX code on a Z, so I think that cable was changed.
jbtech
« Reply #16 on: December 02, 2022, 03:03:52 AM »
Thanks Troy Abercrombie for submitting this info to me:
1967 Camaro SS 396 4 speed
Build date:  06E
Plant:  NOR
Stamp Code: CA
Grommet Stamp:  (TBD)
Engine: L35
Transmission: M20
Final Gear Ratio: (TBD)
Jose
67 Camaro L78
124377N212598
jdv69z
  • 69 RS Z/28 52E
« Reply #17 on: December 02, 2022, 03:23:24 PM »
Where is the cable stamped? Can I see it easily? Pretty sure mine is original.
Jimmy V.
KevinW
« Reply #18 on: December 02, 2022, 03:28:37 PM »
Great info!
CW - L48/M20, BB auto & man (is what I need for my car)
But it would be good to know the original lengths.  I am confused with the lengths the repros are available in.
Thanks!
David K
  • Dr. Longblock
« Reply #19 on: December 03, 2022, 05:18:13 PM »
Jdv69z, see post 5…might help.
« Reply #20 on: December 03, 2022, 06:40:35 PM »
There’s no one spot the cables are stamped.  You will just have to look the cable over completely but I’d start at the trans and work towards the firewall.
x66 714
« Reply #21 on: December 03, 2022, 08:07:53 PM »
Mine was about half way but the next car might not be....Joe
R68GTO
« Reply #22 on: December 04, 2022, 02:44:00 AM »
Mine is stamped right near the trans fitting
« Reply #23 on: December 17, 2022, 04:06:18 AM »
I'm playing catch-up to posts.
Below is what the 67 LOS has.
Build date: 04B (04/13/1967)
Plant: LOS
Stamp Code: CA
Grommet Stamp: RP
Engine: L35
Transmission: TH400
Final Gear Ratio: 3:07  Rear Prefix- 0404 BJ
« Reply #24 on: December 18, 2022, 03:14:45 AM »
Awesome thank you Mike.!!.
« Reply #25 on: December 19, 2022, 04:02:29 AM »
Below is what the 68 LOS has.
Build date: 12E (01/03/1968)
Plant: LOS
Stamp Code: CA
Grommet Stamp:
Engine: L35
Transmission: TH400
Final Gear Ratio: 3:07  Rear Prefix- PP  1216 G1
« Reply #26 on: December 19, 2022, 04:15:44 AM »
Below is what the 69 Z11 has.
Build date: 04C (04/21/1969)
Plant: VN (LOS)
Stamp Code: CV
Grommet Stamp:
Engine: L48
Transmission: TH350
Final Gear Ratio: 3:07  Rear Prefix- BL  0326 G2
