Author Topic: Petronix distributor conversion with TIC TOC Tach  (Read 12699 times)
Daniel Cate
« on: April 24, 2007, 03:58:13 AM »
Hey guys,
When I assembled my car, I had installed a Petronix HEI conversion within the stock distirbutor. My tic toc had only worked intermittently since. I figured bad ground or something simple right? Well I decided to change out the printed circuit while I was at it, as it was rough looking and now I have no tach. Since this car was built from scratch I had never had it running before the Petronix install. Would that have anything to do with it, or am I still searching for a ground issue?
Thanks, Dan
Re: Petronix distributor conversion with TIC TOC Tach
« Reply #1 on: April 24, 2007, 04:32:03 AM »
Dan -
Did you buy the correct printed circuit board?  The one for use with the tic-toc-tach:
http://www.rickscamaros.com/cgi-local/SoftCart.exe/cgi-local/smpagegen.exe?U+scstore+qgfg2505fffd17fd+-p+-c+scstore.cfg+CDP-15
Daniel Cate
« Reply #2 on: April 24, 2007, 05:06:14 PM »
Paul,
Yes I did get the one from Ricks. I think it still may be a groud issue. But I wanted to make sure that it was not related to the Petronix conversion.
Thanks, Dan
Farm Boy
« Reply #3 on: July 11, 2007, 12:33:01 AM »
I have a Petronix 1181 module in the distributor in my '67 and my 40 year old tach works perfect.
fireZ
« Reply #4 on: July 12, 2007, 12:25:55 AM »
I also have the 1181 set in my 68 Z and everything works fine. Look for a ground problem and also check were the 2 wires exit the distributor for a short against the dist. body.
1968 Z28 LA Built
LIC # RPO Z28
67camarorsss
« Reply #5 on: July 19, 2007, 08:00:42 PM »
PWB (Printed Wiring Board) on the dash cluster for a 67 is the same for tach or gas gauge. The only difference is in which wire goes to the connector. IIRC, the pink wire is used for the tach. In 68 they had 2 different types of PWB - 1 for the Tic-Toc-Tach and 1 for everything else. I don't know about the 69.
- 1967 RS/SS 396/TH400 (loaded clone restification)
- 1998 Z28 LS1/M6 (daily driver)
- 2002 Z28 LS1/4L60E (12 sec toy/bookend to the 67)
