Author Topic: Crossram and headers  (Read 11483 times)
Coltdogg556
Re: Crossram and headers
« Reply #15 on: September 12, 2022, 04:54:57 PM »
Replacing original Z28 intake/carb with a crossram generally means you want your Z28 (to look at).. rather than to drive...  but DRIVING a 'stockish' Z28 is so much fun!
Not all true. I am restoring my car to drive. I may take it to a few small car shows here around the Oklahoma area, but but I am not doing it for a car show only car. The one listed above  and the one you posted are the same cars. I know Paul's car is a show winner but I do know he drives it.   Now I am not going to lie, you are right. Driving a stock 68Z is fun. I have not got to do that in many years but it was a fun car I was in.
Now the reason I want a crossram is cause of my father. He is a big 56 Chevy guy and he done a few with a 2X4 set up and he loves it.  He is the one that helped me get my 68Z  and I thought the best way to honor him would be with the crossram.  Maybe I am crazy for restoring a driver with some of the baddest parts that was made by Chevy in the late 60's,  but its my dream car and I will not let anyone stand in my way.
68 07C  Z28 UU, No Console,  No Tach with factory power steering. With 1968 Blip Top Cross Ram...
« Reply #16 on: September 12, 2022, 06:18:01 PM »
I applaud your enthusiasm and if you have ever checked my 68Z build thread than you know I also appreciate what you want to accomplish. Congrats and enjoy the journey..... Now, just a few words on the cross-ram as yes they can work fine but better find out in advance what has to be done. One of the main things is idle circuitry and using a recipe to assist with making it work fine. As stated prior we have an original Quinn certified cross-ram and carbs on our 69Z but its stroked, solid roller, and engine re-built from ground up to use the cross-ram (our recipe).  How's ours run, GREAT and not afraid to drive it anywhere. Congrats again!
BRG Z28
« Reply #17 on: September 13, 2022, 03:36:52 AM »
Thank you for the kind words. I drive my crossram Z all of the time without any issues. If it is set up right, the only issues you will have is keeping your foot out of it and stopping at every other gas station.
Normal driving around town, you would not be able to tell my crossram Z set up from a single four Z
- If I had to pick out some negative aspects of having a crossram;
- Starting it when it is cold out (no chokes)
- You have to keep a higher idle (around 1200-1500).
- When you put your foot into it, my car experiences a slight bog before it takes off. (This is especially seen with the 4210’s).
« Reply #18 on: September 13, 2022, 04:51:40 AM »
Good point on the 4210. The stepping improvement of the linkage on the 4295 helped this out a great deal.
crossboss
  • ^ New engine project
« Reply #19 on: September 13, 2022, 04:58:38 AM »
These are common issues running a Cross-Ram.
"Starting it when it is cold out (no chokes)" No chokes and no heat risers. All that cold gas/air has not expanded yet.
"You have to keep a higher idle (around 1200-1500)." With that huge plenum and long runners there is no velocity. A higher idle helps build up the speed.
"When you put your foot into it, my car experiences a slight bog before it takes off. (This is especially seen with the 4210’s)." Not uncommon. Lean hesitation off idle. Needs more pump shot from the carb(s). Remember, any carb with a 1.1 opening rate will encounter horrible booster signals. MAYBE another carb(s) can and will cure these issue(s). Let the experts chime in on this one.
I experienced the same with my brand X set up. The fixes/cures are in the tuning aspects, time, and patience. In some cases, internal surgery was required on the plenum/runners/dividers.
« Last Edit: September 13, 2022, 05:43:59 AM by crossboss »
1968 Olds 442 W-30
David K
  • Dr. Longblock
« Reply #20 on: September 13, 2022, 04:09:31 PM »
For those reading this thread who have never driven nor ridden in one, remember everyone has an opinion about this setup. I have ridden in one in one with chambered exhaust. They’re a beast to get warmed up and require some finesse to get moving from a stop… until they get some heat in them. If I ever get another project to build, I’m going this way because it tuned me in to what I liked.
I’m confident the engineers at GM didn’t casually put their stamp of approval on this and kick it out of the office. Do it right the first time using the correct parts, and all will be right in your crossram world. Pretty sure you’ll be the only one a the show or cruise or cars and coffee with one.
BUILD ON I SAY!!
« Reply #21 on: September 13, 2022, 05:04:50 PM »
David you are spot on. It takes the right specific parts (T.I., headers, cam, etc) it also takes the right build. Wayne is extremely helpful , and very generous with his time throughout the process. He loves helping guys out to make sure they get it right. The cross ram is Z/28 history and really takes the car into the rare air territory. With the right build there is a lot of fun to be had, and it is second to none for how cool it looks.
BRG Z28
« Reply #22 on: September 13, 2022, 06:56:52 PM »
The bog off the line in my car is so slight, but I thought I would mention it. I was told playing a little more with the rear carburetor will minimize it even more. This is less of a issue with the 4295 carburetors, because they are double pumpers and have the “W” slotted progressive lineage.
The real key to drivability is headers and transistor ignition.
David K
  • Dr. Longblock
« Reply #23 on: September 13, 2022, 07:45:18 PM »
As a follow up I will say the fun factor is worth every penny. The sound, the unruliness, the “not ready to drive yet and I’ll let you know it” is part of the charm. Serious personality disorder, but once you understand it…..
Next to the 68 Road Runner 426 Hemi 4 speed I was a 16 year old passenger in….
Or the GNX I was a passenger in-delivery driver had to move them around the trailer……FUN FUN FUN!!!
I consider myself lucky to have had the opportunities.
Forgot the ride in this one back in the 90s at John Hoopers US Muscle parts business. They had a Camaro show. See picture of car
« Last Edit: September 13, 2022, 08:08:03 PM by David K »
crossboss
« Reply #24 on: September 13, 2022, 07:57:19 PM »
My worthless two cents...
My own experience with Cross-Rams (brand X), tells me the OEM Chevy 'correct' carbs for this application is not good for a street/mild performance for 'drivability'. Why? A 1 to 1 (X8!) linkage is horrible on the booster singles, and that alone will cause most of the issues in my view. The 'correct' carbs maybe the way to go for a show/race car, however, not the 'best' for performance. Try using dual 465-600 cfm vacuum secondaries or double pumpers carbs. This does seem to work well on the Brand X versions. Its not the name on the valve covers to worry about. Remember, Cross-Ram working 'theories' are very similar across all types...using a big plenum, long runners.
1968 Olds 442 W-30
« Reply #25 on: September 13, 2022, 09:20:39 PM »
Crossboss maybe for Ford, not the case for Chevrolet.
 I have actually interacted with number of guys running cross rams on the street, and 99% of them run a version of the 4295, wether original or re-issue, and get the most out of the set up that way. I do know one guy that ran a set of 600 carbs, and while he improved the performance over the stock 4 and tried many cams, and tweaks, it is still the original set up of the intake and carbs that seem to pull the best and the parts perform the best together. Martins recent engine build which went the route of find the best of the best to perform, also used 4295's, and they got 480hp on the dyno.
crossboss
« Reply #26 on: September 14, 2022, 02:57:16 AM »
Not doubting your wisdom. Remember, the key on the street and mild track use is to gain drivability, throttle response and torque. Yes, any torque gained on a low torque engine like the DZ 302 is in my book better than 'peak' horsepower on a dyno. A dyno never won a race. Believe me I have raced, and street driven a car with a Cross-Ram. Yes, it was with a Boss 302. An engine that is the worst for low end response especially with a Cross-Boss, Inline carb, a radical cam that idled @ 2,500 rpms. A total dog below 4,500. On the race track, look out. On the street, it was a fine line on being un-street worthy. Yes, different animal, different engine. Same type of intake manifold. Just passing along my perspective on all of this.
1968 Olds 442 W-30
MO
« Reply #27 on: September 14, 2022, 04:58:13 AM »
I have a friend with a stock 302 and ignition, crossram, headers and chambered exhaust. I have driven it many times and it is the easiest of high performance cars to drive. No hesitation or stumble and no excessive high idle. It can be done, you just have to figure it out.
« Reply #28 on: September 14, 2022, 07:02:51 AM »
There are tame Cross ram builds as well. Wayne helped Gene with a build last year and the goal was performance but with street drivability. In the end it was not a radical built motor but one that had a great amount of giddy up, but idled well and the power band came on way smoother than the a track based brute with gobs of power that only comes in at a high rpm. The are many different way to skin a cat. 😉
So to your point Crossboss, there is some sacrifice with having street/strip machine with it, but there are plenty of guys who have mastered how to do it. The 480HP number is impressive because it was a build meant for the street and to have street manners but still be able to utilize that kind of power consistently less the trifles under lower rpms.
crossboss
« Reply #29 on: September 14, 2022, 08:59:53 PM »
I agree with you. The Chevy would be a better 'drivable' version with a Cross-Ram then say one with a Boss 302. Big port engines on the street are very lazy. Maybe that is the key here. Hopefully, one day I will own a '69 Z/28 with a Cross-Ram!
1968 Olds 442 W-30
