Author Topic: General Question  (Read 2590 times)
Chuck-68-Cam
  • It is what it is
General Question
« on: July 26, 2022, 08:11:37 PM »
I am looking at my old install of the harness to fuse box. It looks like they had the box mounted of the fire wall liner. My new fuse box has a seal on it. Should I cut away that liner and mount the gasket directly to the inner fire wall or bolt it up over top like the old on was? I am thinking it should not be over top of the liner.
Chuck
68 Camaro SST 350/TH400
Re: General Question
« Reply #1 on: July 27, 2022, 01:53:22 AM »
Right reasonably sure the seal goes flat on the firewall, else how would it seal ? I don't remember my firewall pad under the fuse panel when I took it out - try the AIM for the assembly sequence.
Chuck-68-Cam
  • It is what it is
« Reply #2 on: July 27, 2022, 01:26:21 PM »
Thanks Steve.
Yea, I looked through it and did not see anything definitive. But I am with you. I think I will trim the liner to get that seal.
Chuck
