Soooo, I am running the new headlight harness and ran into an issue.
The old harness that was plugged into housing was designed so that the 2 contacts and black piece were put in from the bulb side.
The harness ends I have are longer, and from looking at pictures on eBay they just twist into the housing from the rear.
Even if I cut the new wires, the white connector will not seat correctly in the housing because it is longer.
Any one know why the difference? Do they sell just the housing for these lamps? Am I stuck getting new lamp assemblies?
Thanks for any and all help.
