Author Topic: Urgent - Need Info on Correct AC Delco Air Filter  (Read 4552 times)
gwp4
« on: July 09, 2022, 03:40:24 AM »
Hi Camaro Experts:
I have a 1968 Camaro 327/210 hp 2bbl carb standard base model coupe no ac.  Urgently need to find the correct AC Delco air filter to use for judging and any info on where I can purchase one.  Many thanks.  gwp4
David K
  • Dr. Longblock
Re: Urgent - Need Info on Correct AC Delco Air Filter
« Reply #1 on: July 09, 2022, 04:21:00 AM »
Putting the part number you need here will definitely help.
gwp4
« Reply #2 on: July 09, 2022, 05:59:17 AM »
Hi - I would definitely include the part number for the correct AC Delco air filter if I knew it.  Thanks.  gwp4
PURESS
« Reply #3 on: July 09, 2022, 12:40:44 PM »
The AC part number is A169CW
KevinW
« Reply #4 on: July 09, 2022, 01:10:40 PM »
Interesting, I have a car that uses this air filter (early build 69 with 327 2bbl) and going with an aftermarket.  But the question is, did the judges actually require you to open the air cleaner lid to verify the correct filter?  That is some serious judging!
David K
  • Dr. Longblock
« Reply #5 on: July 10, 2022, 04:06:51 AM »
Yes they do…hence the need for the filter.
