When the problem disappeared, we were running an MSD distributor and ignition box wired directly to the battery. In prior attempts to solve, I had replaced both the distributor and coil with no change in symptoms. That leaves the wiring from the positive side of the coil back to the ignition switch on the column. Wire from firewall block to coil just replaced, so that leaves the stuff from the fuse box back to the column switch, and I guess the power from the battery to the column switch. What could go wrong in those areas that only shows up with the engine under load?
