Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Mild Modifications
Adding factory Console Gauges And Replacement of Fuel Gauge with T3
« previous
next »
Print
Pages:
1
2
All
Author
Topic: Adding factory Console Gauges And Replacement of Fuel Gauge with T3 (Read 22582 times)
Chuck-68-Cam
Member
It is what it is
Re: Adding factory Console Gauges And Replacement of Fuel Gauge with T3
Reply #15 on:
August 06, 2022, 06:23:31 PM »
Yea I have pictures. Fuel was pretty straight forward. I ran red wire to pink post, green wire to brown post, black to ground and yellow to yellow connector from console harness. Then plugged it into the mounting hole provided. (without a bulb)
Logged
Chuck
68 Camaro SST 350/TH400
Chuck-68-Cam
Member
It is what it is
Reply #16 on:
August 06, 2022, 06:29:29 PM »
For the Tach, I cut #2 brown wire from cluster plug. The brown wire comes from the coil negative side. I attached the yellow wire to the connector side and the red wire to the coil side and grounded the black wire. Then mounted it on the rail behind the cluster.
Logged
Chuck
Chuck-68-Cam
Member
It is what it is
Reply #17 on:
August 06, 2022, 06:33:23 PM »
More
Logged
Chuck
Chuck-68-Cam
Member
It is what it is
Reply #18 on:
August 21, 2022, 07:48:51 PM »
Just a follow up...Finally got the fuel down low enough for the low fuel light to trigger. Works like a charm, and the Tach is also spot on.
Logged
Chuck
Print
Pages:
1
2
All
« previous
next »
Mild Modifications
