Author Topic: Engine stall  (Read 7453 times)
HustleRussell
Engine stall
« on: June 13, 2022, 12:00:23 AM »
Mild 305 engine. Performer intake, headers, mild camshaft, Holley 600 vac secondaries,
TH 400 transmission.Overall it runs good. The problem I’m having is going from
idle to wot and back to idle as quickly as possible in gear the engine stalls. I’m
Completely stumped. Any advice much appreciated. Forgot to mention the secondaries
are wired closed, only front half of carburetor is functioning.
Russ
68 RS
69 SS
uscrichter
Re: Engine stall
« Reply #1 on: June 13, 2022, 10:15:20 PM »
Check the carb to intake manifold for slight vacuum leak.
Fred Mertz
Re: Engine stall
« Reply #2 on: June 13, 2022, 11:05:19 PM »
If you don't find a vac. leak try richening the idle mixture adjustment.
David K
  • Dr. Longblock
Re: Engine stall
« Reply #3 on: June 14, 2022, 12:21:42 AM »
Accelerator pump maybe.
HustleRussell
Re: Engine stall
« Reply #4 on: June 14, 2022, 01:20:36 AM »
Thanks for the replies. I’ve sprayed starting fluid around carburetor and intake, no change in rpm.
I’ve adjusted idle mixture for maximum vacuum of 17hg at 950 rpm.
Accelerator pump is working as it should, tried squirters from 25 to 40, has no effect on stall.
Currently using a 31 squirter. I did notice something I thought was odd, holding engine speed at 3000 rpm fuel is just starting to drip from the main boosters. Shouldn’t the main metering circuit be fully engaged at a lower rpm. I believe it’s still pulling fuel from the transfer slots?
Russ
68 RS
69 SS
olddragracer
Re: Engine stall
« Reply #5 on: June 14, 2022, 01:35:37 AM »
Engine stalling from operating conditions you describe does not sound unusual. Likely stall only occurs when the car is at rest or moving slowly. Many engines have a vacuum device that slows the carburetor returning to idle to prevent stalling. When the car is at driving speeds the transmission will keep the engine turning over and keep it from stalling.
Re: Engine stall
« Reply #6 on: June 14, 2022, 04:47:58 PM »
Why????
HustleRussell
Re: Engine stall
« Reply #7 on: June 14, 2022, 06:59:20 PM »
I thought it would be easier to tune the main metering, accelerator pump
and power circuits if the secondaries were not functioning.
Russ
68 RS
69 SS
Tinkerr
Re: Engine stall
« Reply #8 on: June 14, 2022, 09:39:16 PM »
Have you checked the float level? Remove sight plugs, bump the fender. Should get very small splash of gas.
HustleRussell
Re: Engine stall
« Reply #9 on: June 15, 2022, 12:46:11 AM »
Float levels are set as tinkker description.
Russ
68 RS
69 SS
