Author Topic: 67 T400 shifter to tunnel seal  (Read 2270 times)
big iron
« on: May 23, 2022, 03:05:56 AM »
67 AIM M40 A7 #1 shows same as M35 A8 #4 3895281 seal. 3895281 seal is for the PG shifter and can be used on T400 shifter but I do not think it is correct.
I am restoring an RPO M11 shifter and it uses a 3912612 seal (68 AIM M11 A3 #12) which is not as deep as the PG seal (2"vs 2 3/4"). The M11 shifter (M11 A3 #11 3912607) is the same shifter used in 67 (M40 A7 #2).
Could someone with a 67 T400 check to see if the PG seal (2 3/4") was used on the T400 shifter in 67?
Bob
