Author Topic: 69 Saginaw 4-speed reverse lock out lower rod  (Read 2122 times)
vabeach56wagon
« on: May 16, 2022, 03:05:10 AM »
Does anyone have either a source for the Saginaw lock out rod (shifter to bellcrank) or its dimensions so I can make one to spec.
Small-blocks use lower lock rod 3955773 on the Saginaw, not the same as Muncie, seemingly much shorter rod due to the difference in placement of reverse in the cases.
