Author Topic: Help Value for Z28 NOM  (Read 5936 times)
GI JOE
« on: May 11, 2022, 12:49:41 AM »
I came across a 69 Z28, NOM, missing most z28 parts in engine area, no docs, early pre- x code car,
condition from owner is about #3 daily driver with no issues... Car is a turn key...  something you wouldn't worry about getting a bug splat on it...
I just don't know what these cars are worth now a days....
Can someone help me ?
Thanks Joe
PS I believe the car is a real Z from what I checked so far...
SFC GI JOE - Airborne Paratrooper
68- L-78, M22, BV
69- L-78, M22, BV, Conv
David K
  • Dr. Longblock
Re: Help Value for Z28 NOM
« Reply #1 on: May 11, 2022, 01:17:06 AM »
It was born a Z, but the Z parts are missing. It’s now a Camaro that was built with other parts. It’s whatever you think it’s worth. Nothing more, nothing less.
What does NOM mean?
GI JOE
« Reply #2 on: May 11, 2022, 01:19:56 AM »
NOM = Non Original Motor
68- L-78, M22, BV
MO
« Reply #3 on: May 11, 2022, 05:36:20 AM »
Is there anything to substantiate that it is a Z/28?
BRG Z28
« Reply #4 on: May 11, 2022, 09:07:36 PM »
There should be a “X” code behind the back seat usually on the passenger side of the car.
GI JOE
« Reply #5 on: May 11, 2022, 09:29:34 PM »
from the seller
cowl tag 10B
car has 12 bolt stamp BU 1001G2   E
Tach 7k red 6k
power booster 9204 -244
PDB but wrong master cyl
pitman arm 5.8"
X3 with glue over it
Rally's not from the car
NOM is SBC400
muncie 4 speed
car is dressed correctly but has later rear spoiler from  photos posted
any suggestions...? I have just a few more  things to check and verify. I'm traveling tomorrow to see it.
Thanks much
68- L-78, M22, BV
GI JOE
« Reply #6 on: May 11, 2022, 09:47:38 PM »
here is the cowl... does it look correct?
68- L-78, M22, BV
Gars68Tux
« Reply #7 on: May 11, 2022, 10:28:25 PM »
I'm like you, can't keep up with the inflated prices over the last few years. Using the Hagerty "valuation tool", they're showing 80-90K for a number 3 (condition), 69Z! :o Hard to imagine. I'm guessing those would have the original block.
Sounds like you're familiar with what to look for. Check the partial VIN on the trans...and bring on the photos, please. :)
Garth
68 RS L30 AA 749 Fred Gibb Chevrolet
jdv69z
  • 69 RS Z/28 52E
« Reply #8 on: May 12, 2022, 02:03:20 PM »
Yes photos would help. There are quite a few Z only detail items that may still be present. Original factory Hurst with back drive linkage present? If the X3 on the rear bulkhead is original, it is a Z. My Z is also 10B 1968. I have pics of my rear bulkhead X mark. Same week might be similar. Driver's side dual exhaust plate present? VIN range should be 516xxx-521xxx.
Jimmy V.
fiveforty
« Reply #9 on: May 12, 2022, 02:04:44 PM »
Pretty sure that car came out of Maine a few months ago. I had talked with the owner but he had a deposit on it.
« Reply #10 on: May 12, 2022, 05:21:29 PM »
Only worth the sum of the parts and quality of work. I never pay too much for cars through my network. I own a shop. I passed on a 69Z project two years ago because the shop threw out the hidden VINs. Original drivetrain gone. Not original drivetrain means it is just another Camaro. Build those cars like you want to. No docs no value.
MO
« Reply #11 on: May 13, 2022, 03:38:33 AM »
Get the car appraised by a pro. Without docs, that may be the only way possible to find out if it started out as a Z/28. It may only be worth the sum of its parts, but the base would be worth more if it truly is a Z. That's better than being a clone.
GI JOE
« Reply #12 on: May 13, 2022, 07:12:09 AM »
UPDATE
I passed on the car.  I had a 3.5 hour drive to see it and I didn't have my wife's blessing....
The car did come out of Maine... and it sold $45000.00 in less than a day.
Thanks for all the help....
68- L-78, M22, BV
69 Zee
« Reply #13 on: May 16, 2022, 07:27:28 PM »
Should or could...but not always.
Darrell
fiveforty
« Reply #14 on: June 12, 2022, 05:00:04 PM »
Was back up for $39000 by same seller.
