Author Topic: Muncie M-20 Rebuild kit  (Read 5049 times)
57s67
« on: May 08, 2022, 04:09:32 PM »
My 67 RS/SS was purchased as a roller with the original 350 and M-20 rebuilt, but, not installed in the car.  When I bought the car the previous owner provided me with an invoice for transmission repair.  The invoice included $250 for a rebuild kit with reverse gears.  The car is now on the road and I notice that when in 1st gear and not under load the trans will pop out of gear.  I searched the forum and found an old post mentioning worn sliders (part of synchro unit) could be to blame.
My question is would a transmission rebuild kit like I described above include the 1st to 2nd sliders?  Any thoughts on other to diagnose problem?
rszmjt
Re: Muncie M-20 Rebuild kit
« Reply #1 on: May 08, 2022, 10:24:10 PM »
Usually rebuild kits do not include the outer sliders. Weird it’s jumping out of 1st because usually the 1-2 slider does not wear much on the 1st gear side. Do you have a stock shifter or a Hurst ? May just be a shifter adjustment
57s67
« Reply #2 on: May 09, 2022, 01:19:44 AM »
New Hurst Competition Plus.
Kelley W King
« Reply #3 on: May 09, 2022, 01:51:12 PM »
If your shifter has the shift stops which it should I would back them out. You don,t really need them except racing anyway. If it is the slider I would do both while the trans is out or the "feel" of the 1-2 vesus 3-4 shift will be different.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
rszmjt
« Reply #4 on: May 09, 2022, 01:52:25 PM »
Check the rear shifter stop adjustment bolt (which is for 1st & 3rd ) and make sure it is not screwed in too far when in the 1st gear position, ( check in both positions )  and also make sure shift handle and 1-2 rod is not contacting anywhere .
57s67
« Reply #5 on: May 09, 2022, 05:30:21 PM »
All good ideas.  Hadn't thought of backing off the 1-2 stop
