Author Topic: VIN and cowl tag  (Read 6666 times)
chevysscamaro68
VIN and cowl tag
« on: April 18, 2007, 11:27:57 PM »
Hey guys, should the last 6 digits on the VIN on a camaro match the cowl tags six digits after NOR?
olympic69
Re: VIN and cowl tag
« Reply #1 on: April 18, 2007, 11:36:18 PM »
No, the VIN and tag BDY Fisher body sequence numbers are two different things.There is some degree of corellation however.
Rob
Olympic Gold X33
"Its all crazy..."
« Reply #2 on: April 19, 2007, 02:52:05 AM »
chevysscamaro68
« Reply #3 on: April 19, 2007, 04:59:49 AM »
Thanks guys, my only other question after reviewing the above link given, is on my cowl tag I have UU as Paint code , chart only shows U , what is the other U???
Mark
« Reply #4 on: April 19, 2007, 01:34:06 PM »
First U is the lower lower body paint code, second is the upper body paint code.  In your case both the upper and lower body is the same color.  If you had a Vinyl top then the second letter would be replaced with a number like 6 for white vinyl, or 2 for black.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
