Author Topic: repoe 14 x 7 steels  (Read 7528 times)
blackss69
Re: repoe 14 x 7 steels
« Reply #15 on: April 25, 2022, 06:03:21 PM »
I'm looking at repro steel wheels also to replace stock XT wheels.  69 SS with stock disk brakes on front.  Did you measure the center hole diameter and the wheel offset?  Are they hitting the calipers?  What vendor are the wheels?
69camaro
« Reply #16 on: April 25, 2022, 06:10:50 PM »
same situation as you, rims hit the caliper. purchased from Classic Industries
x66 714
« Reply #17 on: April 25, 2022, 07:01:24 PM »
What's wrong with the "XT" wheels? I like them....Joe
« Last Edit: April 25, 2022, 07:24:42 PM by x66 714 »
GMAD_Van Nuys
« Reply #18 on: April 25, 2022, 09:09:00 PM »
If these are the 14 x 7 inch steel wheels, I would call Classic Industries as they do not indicate that they will not fit on a 1969 Camaro with disc brakes:
https://www.classicindustries.com/product/1969/chevrolet/camaro/parts/a8500505.html
From your photos, it appears that you have the factory single piston calibers.
69camaro
« Reply #19 on: May 05, 2022, 05:58:34 PM »
I have an update, bought a pair of XT rims (originals), hand fitted the rims they went on ok, then I decided to tighten a few nuts. Did that, then tried to turn the rim/spin and no movement at all. the rim sat tight against the caliper. I give up!
Will just install spacers................
David K
  • Dr. Longblock
« Reply #20 on: May 06, 2022, 01:49:45 AM »
Are there any codes stamped on the rim? Manufacturing name? Not all wheels fit disc, steel AND Rally….been there done that. Sounds like the offset is wrong enough to give you the issue. Let up know.
