Author Topic: 4053 carb power valves  (Read 7815 times)
wisemanz28
« on: April 22, 2022, 12:09:38 AM »
Trying to figure out my power valve size. Wanted to share the pics and get the groups opinion. The first pic is the primary side, second pic is the secondary side
169INDY
Re: 4053 carb power valves
« Reply #1 on: April 22, 2022, 01:07:26 AM »
Knowing what power valve you have is as easy as reading numbers. The face of this power valve has the numbers 8 and 5 on it. That means that this valve opens at 8.5 inches of vacuum.
Reference: Link
https://www.racingjunk.com/news/choosing-the-right-power-valve-for-your-holley-carburetor/
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
crossboss
  • ^ New engine project
« Reply #2 on: April 22, 2022, 03:10:36 AM »
8.5
1968 Olds 442 W-30
wisemanz28
« Reply #3 on: April 22, 2022, 11:13:07 AM »
I also am seeing a number 6, I just wanted to be sure.
69DuskBlueRS/Z28
« Reply #4 on: April 22, 2022, 02:30:46 PM »
If you need a couple of 8.5" new Holley power valves, send me a PM.
rszmjt
« Reply #5 on: April 22, 2022, 04:12:20 PM »
First picture of the primary metering block has a 65, second picture of secondary block has a 85.
You read the numbers on the right hand side, the left side with the aplha numerical digit with a number underneath it is not a identifying number. You can also tell the higher value power valve by the effort it takes to push the other side of the valve although the difference between 65 & 85 is negligible.
Jerry@CHP
« Reply #6 on: May 16, 2022, 02:35:06 AM »
We've been using 6.5s with our restos.  They seem to work better for the street.
Jerry
vabeach56wagon
« Reply #7 on: May 19, 2022, 01:44:39 AM »
Have you considered plugging the secondaries' power valve opening, gone down 1 step in the the vacuum spring and increased the secondary jetting to 84-86?
crossboss
« Reply #8 on: May 19, 2022, 04:33:59 PM »
Nope, don't do that.
FWIW, start out with the stock specs, eg: jetting (68/76), power valves, springs etc. Then IF needed, move up or down. When running, use a vacuum gauge. This will get your tuning spot on for a correct power valve. Also, make sure you do not have any vacuum leaks from cracked hoses, lines, gaskets, etc.
1968 Olds 442 W-30
Jerry@CHP
« Reply #9 on: May 23, 2022, 07:50:57 PM »
A good baseline is 72-76s.  That is standard jetting in the 3310 Holley carb.  If you're blocking the rear power valve, then add 4 to the rear jetting making it 80s in the rear.
Jerry
vabeach56wagon
« Reply #10 on: June 21, 2022, 06:07:37 PM »
Do you stagger jet your 4053?
Do you use the bigger accelerator pump?
What size nozzles do you run?
paul
