Author Topic: Heat shield bolts 274430  (Read 3135 times)
x66 714
« on: March 29, 2022, 11:55:48 PM »
Does anybody know if the bolt (274430) that holds the heat shields on a small block is the same bolt that's used on the oil pan or timing cover? Thank you, Joe
john302
Re: Heat shield bolts 274430
« Reply #1 on: March 30, 2022, 12:32:16 AM »
No its different . Its a regular lock washer or small flat washer on the bolt . Not a star washer like the oil pan /timing cover bolts .Can post a photo if you want .
x66 714
« Reply #2 on: March 30, 2022, 01:04:32 AM »
That would be wonderful. Thank you, Joe
« Reply #3 on: September 16, 2022, 03:52:39 PM »
Maybe some were but all I've ever noted were they were a star washer. I took this picture recently reviewing and confirming that the screw and bottom section of spark plug 2 piece heat shield (drivers side) that bolts to block was installed prior to paint at Flint and bolt's captured washer was in fact a star type locking washer. Picture of Skip's 21K mile late built 09D Z/28 survivor that scored "Time Capsule" at MCACN 2015
