Author Topic: 12 Bolt Posi question  (Read 5951 times)
cwyllie
« on: March 25, 2022, 12:12:21 AM »
 So I noticed as I was pulling my car into the garage, that my diff seemed to be binding. It was almost like a catch or pop if you will. The front wheels were turned and slightly uphill. I drained and replaced lube along with additive, did 20-30 figure 8's in reverse, drove her home and had the same issue.
Is this normal for a Posi? Thank you for any input.
GMAD_Van Nuys
Re: 12 Bolt Posi question
« Reply #1 on: March 25, 2022, 12:42:06 AM »
Unless your car has a Detroit Locker, you shouldn't experience any binding with a Posi.
« Reply #2 on: March 25, 2022, 02:55:14 AM »
you may need to renew or replace your positract lube additive.
x66 714
« Reply #3 on: March 25, 2022, 11:56:57 AM »
You don't say exactly what fluids & posi additive you used. Can you be specific on brands, weight, & type?....Joe
« Reply #4 on: March 28, 2022, 08:13:43 PM »
I use the GM additive for the posi in whatever amount they call for...
There is also a name brand or two with the additive already in it.
rszmjt
« Reply #5 on: March 29, 2022, 12:18:04 AM »
GM/AC Delco additive #992694
cwyllie
« Reply #6 on: March 29, 2022, 01:04:42 AM »
I used Valvoline 80-90 High performance gear lube and one bottle GM limited slip additive 88900330.
x66 714
« Reply #7 on: March 29, 2022, 01:20:34 AM »
Maybe somebody set the clutch packs a little tight. Just a thought...Joe
Kelley W King
« Reply #8 on: March 29, 2022, 11:42:55 AM »
Clutches could be worn. I had a 10 bolt some years ago that I tried everything else on and ended up replacing the clutches to cure the binding.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Stingr69
« Reply #9 on: March 29, 2022, 03:25:45 PM »
If it were mine, I would start with fresh GL4 gear oil and 1 bottle of the GM limited slip additive then do the figure 8's.  If it still snapped on turns, I would add another bottle and redo the figure 8's.  If it still snaps after the second bottle, I would do an overhaul on the differential.  Probably send it to Gary Ramadei if I could not find a trustworthy local shop to service it.
cwyllie
« Reply #10 on: March 30, 2022, 01:21:50 AM »
Thank you all for the input. Much appreciated!
