Author Topic: Valuation of "Barn" Find?  (Read 21744 times)
Jeff_84_Z28
« on: March 15, 2022, 05:28:36 PM »
Hi, new guy here. So long story, but here goes...
So, my father purchased this car as it now sits, in 1980-1981. The story I got from my father is it was purchased from an auction (he was a used car dealer for ever). The hood was locked on so he couldn't see under the hood to see what it was, but could tell it was a big block from the pan. I honestly have no idea how much he actually drove the car. I have only 1 faint memory from a ride in the back seat. He never even registered it (had a dealer plate back in the day). Then in 1985, he went to pull out of the garage, and a brake line blew. That was it. Has not moved since. Was started periodically until probably 1995. Last start, the carb was over flowing with fuel and it was shut off and left to sit.
What's strange to me, is my Father always thought it was an original Z28 that someone turned into a drag car, which is why he purchased it in the first place. Back in 2019 before he passed away, he had "gotten motivated" and cleaned up the garage and I went by to run some #'s and see what we could find out. Here's what he knew about it, and what we figured out.
What he knew about it that I remember:
Fiberglass nose installed
Has line lock
Swapped from manual to auto
Big Block Installed (he thought 427, I believe its a 71 LS5)
Rear End swapped (possibly Ford 9"???)
What we figured out
5k/7k Tach
X11
50 B pnt(dover white w black top)
01A Built First week Jan 69
711 Black Standard Bucket Interior
The Vin is a V8 vin. The Body tag is an X11. The first thing I did to rule out it being a Z, was notice the 5k/7k tachometer. Being the car was only about 11-12 years old when he purchased it, I would think its unlikely the tach was ever changed. There were other things at the time that I cannot recall, but I'm 99% sure this was just a base 307/350 unless someone can show me otherwise.
Finally, after 42 years I am finally getting my hands on the car. Unfortunately it took him passing away for that to happen, I only wanted that car since I was old enough to walk  ::)
My question, is I'm looking for an honest valuation what a car like this would be worth? I had always hoped my brothers and I would make a project out of it some day, but they are all too busy with families and work so I am looking for what would be a reasonable price to purchase it from my mother since she is moving to a smaller home and getting rid of everything and wants to sell the car.
I took a decent look at it the other day but have not gotten it in the air yet. From what I can see, the body/frame/floors & trunk seem solid. The interior is thrashed, the garage window was apparently broken for about 5 years recently and car windows were open so.... I remember the interior being real nice when I moved out in 1999. I can tell the car has been painted at least twice. Was original Dover white, then looks like someone painted it blue, and then the gaudy 1970's black with sparkle in the paint that it is in now.
My plan for the time being would not be a full restore, but just cleaning it up, doing whatever it needs to get it to run and drive safely and just pick away at it and maybe someday do it over proper. I do believe this car would be a great start for someone looking for a 69 to restore also, but am having a hard time determining the actual real value these sell for. I would guess somewhere around 5k, but with a clean body/frame maybe I'm low balling. There is no title for the car, so that still needs to be worked out also. I don't want my mom to not get what its worth. I would be willing to spend up to 5k on it, but to me, other than it being my fathers car, would be more than I would want to invese since I already have my 84 Z28 that I've had since 1998.
There's a bunch of photos at the dropbox link below. Tried to get some date codes where I could. Many of them were taken blindly just reaching under and shooting photos but should give some idea.
https://www.dropbox.com/sh/qafrbwkkwznw9yk/AADUpJsL2Ro-XhMJLFfCnbnYa?dl=0
Thank you for taking the time to read this!
Jeff
Re: Valuation of "Barn" Find?
« Reply #1 on: March 15, 2022, 06:11:40 PM »
Jeff, Sorry for your Loss and prayers for your Family. This is a difficult time and situations. This car WILL take huge efforts and funds to even get safe to run on the road. I would Estimate:
10-15 on the open market. (Purchase)
Friends and family should be a bit favorable to your cost, but,,,,,You are 1st getting in on the ground floor ie. not subject to open market competition and resulting pricing, 2nd your Dollars would be going to immediate family, your Mothers benefit and 3rd your "Dads Car" enough said.
You did well with the photos, good job.
This is a complex situation to buy or not to buy for you.
Wishing you the Best
JIM
Jeff_84_Z28
« Reply #2 on: March 15, 2022, 06:32:38 PM »
JIM
Thanks for the prayers, appreciate it! That much for a base with no matching #'s huh? I was afraid of that. Not sure if you think its the condition that makes it worth that (no body/frame rot) or if that's just the going rate.. Only thing I came across with project cars in similar shape was https://repairablecars-forsale.com/ads/1969_Camaro_Z28_For_Sale.html so I was hoping 5k was a reasonable offer for a base with no matching # engine/trans/rearend that has been molested into a 70's drag car.
And I do know it would take a lot (brakes/wheels/rubber/suspension) to even make it safe to drive across the street. My hopes were that since I know it ran when parked, replacing all the fluids/gaskets and swapping water pump & alternator, and getting the carb rebuilt, and a little bit of luck, would be enough to enjoy the car for the time being. Something to pick away at in the garage.
Stingr69
« Reply #3 on: March 15, 2022, 06:57:06 PM »
Great car and story.  Hope you can find a way to make everyone happy and still keep the car.  Getting a title for it would probably increase the value quite a bit.  I do not know what it is worth but $5k is probably way low today.
Engine is a 454 from '71 or '72  Used in just about any passenger car.
Not a Z/28, but still a great hot rod.
That web site is not a good indicator of the prices in the market.  I would not trust it at all.
Jeff_84_Z28
« Reply #4 on: March 15, 2022, 07:21:06 PM »
That's what I was afraid of. In my mind, its a base $5k molested car. But, then I remember that car is now 53 years old, and all things considered, a solid start for someone looking to restore one.
I believe the Title is easy enough to get where I am. Just need a pre 1990 bill of sale from previous owner. Will just take some work to figure out previous owners name since it was bought at auction. We may uncover the bill of sale or purchase paperwork at some point as we have just started finally going through his things. Knowing him, there is no paperwork. Hell, we can't even find the keys lol.
As far as the motor, I am going to try to pull the valve covers to see what the heads are. Someone did considerable work to hot rod this thing, so maybe we'll get lucky and its got a built motor. From what I have seen, chances are slim to none that its a 4 bolt.
Kelley W King
« Reply #6 on: March 18, 2022, 01:04:44 PM »
To me no title is a large thing (in NC) which would make the value a sum of the value of the parts. Sounds like the motor is just a run of the mill 454. Unless you can get a title it is just an old racecar. A friend just last week bought a very similar 69 (even black) but running and ready for 20K but it does have a DART engine with BDS blower we figured might bring 15k. I think your 5k would be a deal but not unfair to family. Just my thoughts.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #7 on: March 18, 2022, 02:39:06 PM »
Its between family and that can be difficult at times but honestly, the car is worth far north of $5K. If the body is in excellent shape, not cut up, and glass etc. original, its a solid $15 to 20K value IMO as many are looking for a solid car to use to fix up a rust bucket so in those cases a title is not needed. Can your Mom apply for a lost title? And whatever value the race stuff can bring taken off the car. Some of that has value for day 2 cars. Hope it all goes well and good luck.....
Jeff_84_Z28
« Reply #8 on: March 18, 2022, 04:54:20 PM »
I am still hoping to come across some sort of paperwork for it. As I said, I know it was purchased at auction, but I have no idea where or exactly when. I have been told that it is pretty "simple" to get one in MA, just need an old bill of sale. The issue will be tracking down the previous owners name. Anyone have any good ideas on how to find that aside from the obvious of looking in the car?
I did spy some roller rockers in it (img 2766-2768 in dropbox link above). Going to pull the covers this weekend and see what the heads are. I did find it weird that the date code was dated 1969 if I'm reading it right???(k 10 9 in image 5694), but the block stamp for CPD engine is only for 71-72??? Am I missing something?
Casting# 3963512
Engine Pad Stamp T0904CPD vin 11B120446
Date Code K10 9
Jeff_84_Z28
« Reply #9 on: March 18, 2022, 07:29:26 PM »
https://www.dropbox.com/sh/pa4ioobj704s58v/AAANDki6T2qoOfihg4Nw0GA0a?dl=0
Put these up last night but was too tired to type anything. Apparently my "real" camera likes to focus on what you are not trying to focus on in most of the photos. Should have stuck with my phone camera.
Had a couple buddies over and got the car up on jack stands. Basically just got it vacuumed inside and out and tried to get more #'s from engine, rear end etc. From what I have seen, only rust issue is some slight bubbling below the rear windshield trim, and some paint bubbling on the trunk lid. Couple random spots on rockers and quarters where paint is peeling, but it all looks to be minor and on the surface. Is there any places on these cars where rust/rot is hidden? Anywhere to look in particular?
No build sheet under back seat which isn't a surprise. Going to get the tank dropped and see if its up there, which I'm sure it won't be. I would guess the tank needed to be lowered when the in line fuel pump was added, but maybe not. Looks like it has been there for ever.
No tag on rear end, but it seems to be a C7AW-E ford 9" Going to try to get the casting #'s cleaned up.
Going to get some roller skates for it and get it outside and give it a bath inside and out this weekend. I really think it is going to clean up way better than I anticipated after a couple test spots in side and out.
Intake 3866848 (3866948 maybe?) Seems to be a run of the mill intake, thoughts?
Thanks everyone!
Jeff_84_Z28
« Reply #10 on: March 18, 2022, 10:15:59 PM »
Think the link I put up yesterday was no good for the pics... link below should work
LeonardS
« Reply #11 on: March 18, 2022, 10:55:39 PM »
Did you buy it? Once it’s cleaned up, it will look like it’s worth more and the family will probably think you should pay more.
Jeff_84_Z28
« Reply #12 on: March 19, 2022, 01:15:38 AM »
I'm doing what is best for my mother. She needs the cash. It's counter intuitive to improve it but, if its worth more than I can afford, I won't buy it. It sucks, I'd love to have it for lots of reasons.
I basically could afford it for 5k. I figure would probably be at least another 5k to get the brakes, suspension, wheels/rubber, exhaust etc sorted out that it would need to make it streetable. If its worth 6 or 8, maybe ill get the family discount. But it would honestly mean more to me to clean it inside and out, get the carb rebuilt and get it running if it turns out its worth 10 as is. I'd rather try to get her a little more by having a running car to sell. I'd at least be able to play around with it to get it running before sending it off. Like I said, it sucks. I'd love to have it.
Jeff_84_Z28
« Reply #13 on: March 22, 2022, 03:41:42 PM »
Got it out of the garage and gave it a bath to get the first layer off. Started hitting the drivers side a little with just a damp cloth. Interior seems like it will clean up...
https://www.dropbox.com/sh/6a2ji2nlnj2w0ju/AABXUUxz6_7OOHtwnkkZU_zna?dl=0
« Reply #14 on: March 22, 2022, 10:43:10 PM »
$15K in today's market. Solid body, good original interior. But you need to get the title.
Does it have 1 or 2 fuel lines? Looks like front drum brakes.
