Author Topic: Location of voltage regulator  (Read 4047 times)
mdz
« on: February 25, 2022, 01:38:56 AM »
Putting my 69 Z RS back together and having trouble locating the voltage reg on the radiator support. Have installed the horn relay, but cant find the three bolt holes for the regulator. Seems like it should be above and toward the middle from the horn relay, any help, a photo would be super. Thanks in advance.
Re: Location of voltage regulator
« Reply #1 on: February 25, 2022, 03:19:52 AM »
This is not an RS, but voltage regulator would still be in roughly the same spot:
« Reply #2 on: February 25, 2022, 03:41:20 AM »
And here is a photo of mine ('69 RS).. before disassembly for cleaning...
KevinW
« Reply #3 on: February 25, 2022, 11:25:53 AM »
So one thing I had thought about with my car being a "early" 69 was the mounting of the regulator.  I think 67-68 used a rubber isolator to mount it.  But 69 used 3 sheet metal screws.  Could an "early" 69 use the rubber mounts, then it was changed over just a screw later in the year?  So many "68" things on my car, maybe this is a change too.
MDZ, what is your build date? Do you have 3 larger diameter holes in a rough triangle in the pictured location?
« Reply #4 on: February 25, 2022, 12:58:03 PM »
yes early 69's had the isolator nuts.
« Reply #5 on: February 25, 2022, 05:13:04 PM »
MDZ what is the build date of your car? LA or Norwood ? just curious
« Reply #6 on: February 25, 2022, 05:15:29 PM »
And are you using the original radiator support, or a 'reproduction' replacement?
mdz
« Reply #7 on: February 26, 2022, 01:39:04 AM »
Thanks to everyone for the help, photos made it easier to find, build date for my car is 12B and it was screw mounting without any rubber.                    Bullett 65 its a Norwood car. 69Z28RS the core support is orginal GM.Again thanks for the help, this site is the best.
