Author Topic: Spare Tire J Hook & Wing Nut  (Read 9305 times)
« on: February 23, 2022, 12:27:35 AM »
Ok everyone I need some help from some of you guys that know you have the original spare tire, J hook & wing nut.
AIM part numbers
1967 & 68 coupe - 3916608
1967 & 68 conv   - 3841841
1969 coupe         - 3949607
1969 conv           - 3841841
1967 w/ r defrost C50 - Nothing Listed
1968 w/ r defrost C50 - 3823276
1969 w/ r defrost C50 - Nothing Listed
Please do the data as follows please
Year - 68
Plant - NOR
Build Date - 03D
J Bolt Length - 9.5”
Rear Defroster - No
Wing Nut serrated or smooth - Smooth
Wheel Size - 14x6
Wheel code - FC
Photos are encouraged.  Thanks I’m advance!
« Last Edit: February 23, 2022, 02:28:11 AM by cook_dw »
Re: Spare Tire J Hook & Wing Nut
« Reply #1 on: February 23, 2022, 01:01:24 AM »
Year - 68
Plant - LOS
Build Date - 12E
J Bolt Length - 7” (Looks hack sawed?)
Rear Defroster - No
Wing Nut serrated or smooth - Serrated
Wheel Size - 14x6
Wheel code - XG (K17 /   11<O>30  XG)
« Reply #2 on: February 23, 2022, 02:26:23 AM »
Thanks Jim.
x66 714
« Reply #3 on: February 23, 2022, 05:25:23 PM »
Year-1968
Plant- Los
Build date-02E
J bolt length 7-1/4"
Rear defog- No
Wing nut serrated- No
Wheel size- 15x6
Wheel code- DF
x66 714
« Reply #4 on: February 23, 2022, 05:30:32 PM »
Year- 1969
Plant- Nor
Build date- 08E 1969
J bolt length- 9-1/2"
Rear defog- No
Wing nut serrated- I think so
Wheel size- 14x7
Wheel code- XT
« Reply #5 on: February 23, 2022, 06:17:26 PM »
Joe, your 69 wing nut is one I've seen before with that much greater ear angle.
This is Skip's 69 Z/28 info.
Year- 1969
Plant- Nor
Build date- 09D Late
Rear defog- No
Wing nut serrated- Yes (has those teeth like manufacturing marks on the underside)
Wing nut wide angle or slight angle- Slight
Wheel size- 15X7
Wheel code- YH
« Reply #6 on: February 23, 2022, 07:06:09 PM »
Great info gentlemen & keep it coming!  I will add some additional check mark items later on once I actually start the spreadsheet.
« Reply #7 on: February 23, 2022, 07:14:42 PM »
Picture of what calling slight angle vs. Joe's 69SS with greater ear angle.
The tooling teeth like marks are on the underside or what Darrell called serrations, whereas picture shows top side and correct sq nut.
mgreenz
« Reply #8 on: February 23, 2022, 07:56:24 PM »
I'm confident that the spare, j-hook and wing nut are original to my car. There's a photo including the spare attached for your review.
Year - 68[/size]Plant - LOSBuild Date - 04DJ Bolt Length - 7.375”Rear Defroster - NoWing Nut serrated or smooth - SmoothWheel Size - 14x6Wheel code - FC
___
Terry
mgreenz
« Reply #9 on: February 23, 2022, 08:06:02 PM »
Year - 68
Plant - LOS
Build Date - 04D
J Bolt Length - 7.375"
Rear Defroster - No
Wing Nut Serrated or Smooth - Smooth
Wheel Size - 14x6
Wheel Code - FC
___
Terry
« Reply #10 on: February 23, 2022, 08:06:34 PM »
Thank you Terry.
Ok Ive threw together a down a dirty spreadsheet and I'd like to update the listing as to what we need to include.  Thanks Chick for the input also.
Year -                68
Build Date -      03D
Plant -             NOR
J Bolt Length -  9.5"
Engine Code -   L78
Rear Defrost -    No
Wheel Code -     FC
Wheel Size -    14x6
Wing Nut Face - Flat (or Conical reference Joe's & Chick's photos above)
Wing Nut Mating Surface - Smooth (or Serrated reference Joe's & Chicks's photos above)
Wing Nut Angle - Shallow (Or Steep)
« Reply #11 on: February 23, 2022, 09:17:00 PM »
Year - 68
Plant - LOS
Build Date - 04D
Rear Defroster - No
Wheel Size - 14x6
Wheel Code - FC
Terry, looking at your wing nut it appears you might have the indents around the circumference of the hole that is underneath or mating surface Darrell is calling serrated.
Here is what Darrell is calling serrated, the indents or tooling teeth marks of some kind. This is off the above 69Z late 09D NOR car.
mgreenz
« Reply #12 on: February 23, 2022, 11:25:16 PM »
Thanks Chick. Hopefully these photos are better. I believe my wing nut is the same as the one in Reply #3 with only the 4 dimples (spot welds?) on the mating surface.
I'm happy to email photos if you or Darrell would like them.
Year - 68
Plant - LOS
Build Date - 04D
Rear Defroster - No
Wheel Size - 14x6
Wheel Code - FC
___
Terry
« Reply #13 on: February 24, 2022, 12:11:29 AM »
Those photos work. Thank you.
« Reply #14 on: February 25, 2022, 02:58:48 PM »
Would like more info from anyone and everyone with their original spare components.  All years 67 - 69.  Thanks!
