Author Topic: 69 Pinion yoke  (Read 6928 times)
wolfe1
  • Guest
69 Pinion yoke
« on: April 15, 2007, 01:08:10 PM »
I'm having some trouble determining what pinion yoke should be on my 69 Z28. Should it be a 1310 or 1330 series yoke and also, straps or U-bolts. There's a lot of yokes on e-bay that supposedly came off a 69 Camaro 12 bolt and they look like 1330 series. I believe 1310 is correct, but not sure. Thanks
JKZ27
Re: 69 Pinion yoke
« Reply #1 on: April 15, 2007, 04:33:17 PM »
I believe its going to be the 1310 flange. Should be part #3996118 with straps. I just went through the same thing with my 69 SS. I got lucky and found a NOS flange for a good price. It did not look exactly like my original (very close) but works perfect. Hope this helps.
John
John
68 RS Ash/Ivy Gold 327EFI M20
wolfe1
  • Guest
Re: 69 Pinion yoke
« Reply #2 on: April 16, 2007, 02:09:33 PM »
Thanks for the info. That's what I needed to know.
Jerry@CHP
Re: 69 Pinion yoke
« Reply #3 on: April 19, 2007, 01:02:52 PM »
The old GM part number for the u-joint is 386451.  Std joint for that application.  1969 was the first year to use the straps instead of u-bolts.
Jerry
sd1968z28
Re: 69 Pinion yoke
« Reply #4 on: April 19, 2007, 03:26:26 PM »
jerry this is jason from south dakota, did you see the posted pics of my engine numbers?  they are on decoding numbers under 68 z28 engine, zz mike posted them for me.
Re: 69 Pinion yoke
« Reply #5 on: April 23, 2007, 07:34:02 PM »
Jason,
Could you please only post in one thread about your car?
Unless, of course, you wish to discuss 69 pinion yokes. :)
