Author Topic: 67 RS Oil Gauge and Warning Light  (Read 3478 times)
aus67rs
« on: February 22, 2022, 11:40:50 AM »
Hi, restoring a 67 RS convertible with console and gauges.  The dash cluster has the  the "OIL" warning light and the new wiring harness seems to have a connector for a pressure sensor on the engine. Were both the gauge and warning light active on these cars originally?  If so, could someone either describe or post a photo of the sender unit on the engine please? Thanks.
Butternut1967
Re: 67 RS Oil Gauge and Warning Light
« Reply #1 on: April 23, 2022, 09:14:27 PM »
My understanding is either the engine had an oil pressure sending unit and an idiot light in the dash cluster, or it had an oil line fed through the firewall and mounted to the back of a gauge. In this case the sending unit was removed and a fitting installed in the block to accept a compression fitting.
1967 Camaro RS/SS Convertible 11A WXDL 2ELGR 3SL 4P 5Y
Rebuilding of 1967 RS headlight motors
aus67rs
« Reply #2 on: May 02, 2022, 06:42:02 AM »
Thanks, I'll run with that.
David K
  • Dr. Longblock
« Reply #3 on: May 02, 2022, 06:32:13 PM »
Oil light sender
David K
  • Dr. Longblock
« Reply #4 on: May 02, 2022, 06:32:47 PM »
Engine block fitting and line
David K
  • Dr. Longblock
« Reply #5 on: May 02, 2022, 06:33:16 PM »
All available all day.
