- but I’d be surprised if originally R went to G and G went to R.
Well, I am surprised!
Found some disassembly reference pictures from when I disassembled the front end of the car in 2005.
First two pictures I just took today of my original relay valve that I replaced in August 2021. You can clearly see that the relay valve is marked "R" (top port), "Y" (middle port), and "G" bottom port.
However the third picture is the "as found" condition of the hoses connected to the relay valve prior to disassembly in 2005. (Note: the white markings I added as additional reference as to what hose went ot which port). Lo and behold.....the green hose is connected to the top, "R" port and the red hose is connected to the bottom, "G" port.....in agreement with the '68 AIM, but not what the '69 AIM shows.
So during reassembly, for whatever reason, I did not refer back to the third picture below, but instead hooked up my new hoses as per the port markings on the relay valve and '69 AIM. When i did this, the headlight doors operated backward, i.e. closed with headlight switch pulled out, open with it pushed in. My fix was to swap the vacuum lines at the canisters as opposed to doing it at the relay valve. However, it does appear that these cars came from the factory with the vacuum lines swapped at the relay valve...go figure.
For those who think GM/Chevrolet (or any OEM for that matter) is infallible..
Richard
