Author Topic: Disc brake conversion  (Read 8455 times)
hrlyfxdl
« on: February 17, 2022, 07:29:45 PM »
Hello all, hope everyone is doing good. I have a question about a brake conversion and couldn't source an answer on here.
I'm going to be changing over my front drum brakes on my Camaro to disc. I've sourced most of the original parts I'll need to do this (to keep it looking as authentic as I can), but when it comes to the rotor....are there any pros or cons to staying with the 2 piece OEM style rotor in the conversion (other than authenticity) versus installing a 1 piece rotor for the 4 piston calipers? Finding the 2 piece is rather tough to do, but they are available, but was just wondering from experience if there is any advantage of one over the other (again, other than authenticity and maybe the 1 piece is more readily available these days). Thanks for any input you can offer.
Shane
1968 Camaro SS 350 8L34677?
07A  E107  TR 712  U-U
5hane
Re: Disc brake conversion
« Reply #1 on: February 17, 2022, 10:49:01 PM »
If you aren’t worried about the car being 100% original correct (cause if you were you’d keep it drum) then go with a 1 piece rotor.
« Reply #2 on: February 18, 2022, 02:40:08 PM »
Apparently he wants to do the brake upgrade with 'original' '69 Disk Brake parts (or at least original appearing parts), so his question really is:    Are the one piece rotors noticeably different from originals, or are they inferior in any way?
He wants to upgrade his braking capability of the car without using 'visibly aftermarket parts'.   If I were in his shoes, I'd be doing the same thing.
Stingr69
« Reply #3 on: February 18, 2022, 03:15:56 PM »
No, there is no difference.  I actually have 1 of each on the front of my car.
« Reply #4 on: February 18, 2022, 04:49:16 PM »
Wont be "original" if he uses 69 DISK BRAKE PARTS on a 68..
As I said go with the 1 piece cause at the end of the day the price difference isn't worth it unless your car was originally a disc brake car and you wanted to do a "correct" restoration..   Is that better for you Gary?
Petes L48
« Reply #5 on: February 18, 2022, 05:57:01 PM »
Way back in the day, the one piece type had to be machined a little to not hit the lip of 4 piston calipers.  This was back in the mid 80s.  I imagine they've come a long way since then.  When I did my resto a couple years ago, I used the hubs from the original 2-piece rotors, mated to discs from reproductions, with no issues.  But as everyone has said, for your application you can just go with the one piece.
« Reply #6 on: February 18, 2022, 08:36:27 PM »
No it won't be a correct 'restoration' regardless, since his car didn't come with disk brakes.  But I can appreciate wanting to stay with period correct GM parts!
Note:  Many '67-68 owners with factory (four piston) disk brakes choose to convert to '69 disk brakes purely due to their simplicity and maintenance!
hrlyfxdl
« Reply #7 on: February 18, 2022, 09:34:55 PM »
All, thanks for the input. That has really helped. I'm just inexperienced in nuances of these types of conversions, thus the question.
I gave up on originality as far as a pure restoration a long time ago. My car is supposedly a 1968 SS 350, but without docs I can't prove that and the engine is long gone (although I still check the orphans page every single day LOL). You all helped me when I first bought it to decipher some of the indicators of a SS, but again I would never stand on that fact as I can really prove it. But I appreciate the look and engineering/design of how the Camaro was built, thus why I want to have the best of both worlds: better stopping capability as I'd like this car to be a daily driver, but true to how this car "would" have been built if it had disc brakes from the factory.
I've sourced the correct parts where I can, probably from a lot of you guys, date and period correct, from the booster, master, valves down to the backing plates, spindles, brackets. I can buy aftermarket 2 piece rotors, but they are import. I can get the 1 piece rotors that are USA made, and that's what I'd prefer, but just wanted to make sure I wasn't causing issues from a 2 piece to a 1 piece design. I'm still going to buy aftermarket hoses, bolts and brackets that I can't get from used parts sellers. But overall 99%, it will have the same appearance as if it had disc brakes from the factory. I'll keep all the original drum components, just in case some day....
Anyway, thanks everyone for the input and help, makes me feel better going in the 1 piece rotor direction. Stay safe, S
07A  E107  TR 712  U-U
5hane
« Reply #8 on: March 08, 2022, 03:26:32 PM »
Ran across these while doing my craigslist search if there are of interest.  You can buy the rotors from Camaro Central IIRC but you will have 2 piece hubs.
https://pittsburgh.craigslist.org/pts/d/west-mifflin-z28-piece-rotors/7449975249.html
Petes L48
« Reply #9 on: March 08, 2022, 07:49:33 PM »
The rotors only, for the 2-piece hubs, show as discontinued on their site:
https://www.camarocentral.com/1967_1969_Camaro_Front_Disc_Brake_Rotor_for_2_Pc_p/brc-634.htm
« Reply #10 on: March 08, 2022, 07:55:40 PM »
Well that's no good..  I guess its been a few years since I checked on them.
« Reply #11 on: March 09, 2022, 05:09:46 AM »
Heartbeat has the 2 piece assembly in stock for about $170.00 (imported, all grey cast iron, but pretty darn close). You could use them, or bolt the rotors up to the original nodular iron GM hubs if you have a set. At least that gives you the appearance with the functionality -
hrlyfxdl
« Reply #12 on: March 09, 2022, 03:28:41 PM »
Thank you for the lead, I'll give them a call today and see about the hubs, probably ask them to just buy the hubs and forgo the rotors since I'd be replacing them anyway. Appreciate the help, I'll post pics once I'm done.
07A  E107  TR 712  U-U
5hane
x66 714
« Reply #13 on: March 09, 2022, 03:51:50 PM »
Neither piece is serviced separately....Joe
GMAD_Van Nuys
« Reply #14 on: March 09, 2022, 05:28:29 PM »
I would recommend buying a new one-piece rotor as someone can't tell if your car has a two-piece rotor unless they put their fingers inside the slots in the wheel rim (just performed the check).  Although I've bought rebuilt master cylinders and power brake boosters, I wouldn't buy used rotors unless I could inspect them in person to measure the rotor thickness and condition of the bearing races.
