Author Topic: Hunting for a correct 1968 alternator (part # and date code)  (Read 7488 times)
67/68Brian
« on: January 30, 2022, 11:51:32 PM »
Hi all,
I emailed Kurt Sonen and he suggested I post here.
I'm looking for the correct part number and date code for my 68 RS convertible.
Here are the particulars on the car:
1. Cowl tag 09C built in Van Nuys
2. Shipping data report 9/14/67
3. Original dealership Cormier Chevrolet of Long Beach, CA
4. Engine pad stamp 18L 302530  T0907EE
5. Engine is 327/275hp with power steering and powerglide
The Chevrolet by the Numbers book by Colvin is a bit unclear about the part number I should be looking for and I'm also not sure how many days or weeks before the cowl tag date or engine pad stamp date I should be looking for as well. I'm assuming the 37 amp alternator would be most correct?
I enjoy your site and feel fortunate to be the second owner of this numbers matching 68 Camaro since 1991.
Thanks, Brian
x66 714
Re: Hunting for a correct 1968 alternator (part # and date code)
« Reply #1 on: January 31, 2022, 12:18:52 AM »
You don't say if it has a/c or not unless I missed something...Joe
67/68Brian
« Reply #2 on: January 31, 2022, 12:20:37 AM »
Oh, no air conditioning. Thanks !
x66 714
« Reply #3 on: January 31, 2022, 12:26:47 AM »
I come up with 1100794 according to the 1968 Chassis overhaul book. Let's see what others say...Joe
« Reply #4 on: January 31, 2022, 12:42:54 AM »
I concur. 1100794, which was the standard 37 amp alternator.
« Reply #5 on: January 31, 2022, 02:39:12 AM »
Chevrolet Chassis Service Manual
SPECIFICATIONS 11
Engine Electrical Section 6Y
Generator
Camaro V-8 Exc. w/C-60
1100794
Joe & Ed got it!
Date Just see what is avail out on the market and see If you can predate your build by a reasonable and acceptable range
x66 714
« Reply #6 on: January 31, 2022, 11:46:25 AM »
Here's a guy on ebay that has a 7G7 for 25.00....Joe
https://www.ebay.com/itm/373437616310?hash=item56f29dd0b6:g:zAQAAOSwGsheMveV
67/68Brian
« Reply #7 on: February 01, 2022, 06:42:11 PM »
Hi all,
Thanks for the replies. I have a few more questions:
While the Colvin book leans towards 1100794 what about 1100813 for a power steering car? I think the 794 is w/o PS? Am I reading it wrong?
Also, what is an acceptable "date" and is it before cowl tag or engine pad stamp? How much before especially for a Van Nuys car which I'd assume is some distance away from where alternators were made?
Thanks, Brian
« Reply #8 on: February 01, 2022, 06:51:03 PM »
I read the 1100813 as applicable to :
ALL L-6
« Reply #9 on: February 01, 2022, 06:53:09 PM »
Brian, the 1100813 was used on 6 cylinder cars WITH smog and/or power steering. The 1100794 was for all V8 (except the 302, A/C or the optional 62 amp alternator) and 6 cylinder cars WITHOUT smog and/or power steering.
Alternators were installed on the engine dress line so it should be dated a day or so to several days before the car was assembled.
67/68Brian
« Reply #10 on: February 02, 2022, 02:50:07 AM »
Thanks for replies especially clarification on part numbers.
So, date code range is from a few days to a few weeks from engine stamp date for LOS cars?
67/68Brian
« Reply #11 on: February 03, 2022, 03:32:29 AM »
Hi again,
So to clarify with a cowl tag of 09C and engine stamp of T0907EE what is the date code range I’m looking for? I have not seen this “range” listed anywhere.
Thanks very much,
Brian
x66 714
« Reply #12 on: February 03, 2022, 01:23:02 PM »
There can be a little science when trying to find missing components. Even finding a car built around your time frame can't guarantee the parts were the same on your car.
My 1968 Z/28 is a 02E with an assm date of March 13th, 1968. My alternator is an 8A9, so Jan 9th, 1968. Now this car uses a different alternator than your car but it' a little over a month earlier than the assm date of the car. This is an example. I need to find a starter for my car. My friends 1968 Z28 was built at the same plant on the same day. I will try to find a starter with the same date as his, 8A23.
When I crunched the numbers for my 69, a lot of the Delco was withing a month of each other. Still not a perfect science....Joe
« Reply #13 on: February 03, 2022, 02:56:05 PM »
Common parts like starters, alternators and all other components that were attached at the engine dress line for base engines were usually (not always, but usually) much closer to the build date of the car than parts for optional engines. For example, my 68 L78/L89 was assembled the 4th week of May, 1968 and the distributor is dated late March, 1968. The Holley carb is also dated late March, 1968, so you can see there's a big difference. Heck, the aluminum heads are dated late January, 1968!
« Last Edit: February 03, 2022, 10:06:37 PM by bertfam »
67/68Brian
« Reply #14 on: February 03, 2022, 09:56:51 PM »
Hi Ed,
So you are saying on the "base" engines that alternators, carbs, voltage regulators, starters and similar "dated" engine components would likely be dated within a few weeks or a month before engine stamping but "rarer" engines would more likely to be dated a couple of months before?
That makes sense and I think the part number and date information would be great research topics for the website. If I didn't have Alan Colvin's book I'd really be in the dark. With additional info from those that replied I get it now. Just think a central "report" on the website would be helpful to many and would reduce the need to answer so many questions here.
Thanks to you and others at CRG for what you do for the hobby,
Brian
