Author Topic: Best hood insulation out there?  (Read 2938 times)
Driveway_finds
« on: January 19, 2022, 05:06:24 AM »
I’ve done some research and reading , but want to know if companies have made a better hood insulation in recent years and if anyone knows of one! Thank you!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
Check out driveway_finds on Instagram!
camaronut
Re: Best hood insulation out there?
« Reply #1 on: January 20, 2022, 12:04:49 AM »
My bet is that the molded hood insulation is made by one company, and sold to vendors like Camaro Central, NPD, Ricks, etc.
Shipping would be crazy expensive.
« Reply #2 on: January 20, 2022, 01:13:11 AM »
The molded insulation is from a single vendor as far as I know.
The freight was the same cost as the product last time I bought one.
Petes L48
« Reply #3 on: January 20, 2022, 02:27:40 AM »
I think this is the company making the molded insulation, and you have to go through a vendor.  If you ask a Camaro vendor if they use a certain vendor for an item, they will normally tell you if the case. I had a vendor bring mine to spring Carlisle on their truck, to avoid the high shipping cost.  It was a little thick where the clips go through, so we had to remove a bit of material from the backside around those holes.
https://www.remautoinc.com/index.php
Driveway_finds
« Reply #4 on: January 20, 2022, 03:02:28 PM »
Great, appreciate the help guys!
1969 RSSS L78
1970 RS L78 clone
1970 C10 LS swap
