Author Topic: Muncie  (Read 4453 times)
Bigfish45
Muncie
« on: January 18, 2022, 09:48:18 PM »
69 Camaro SS with a 396. Could an M22 be ordered with a 3.73 gear?
Re: Muncie
« Reply #1 on: January 18, 2022, 09:59:27 PM »
Rear axle ratio was not a direct factor.
M22 only available on Z/28, L78 SS, COPOs 9560 & 9561.
Re: Muncie
« Reply #2 on: January 18, 2022, 11:01:53 PM »
As Bill said.
If you met those, yes could be ordered with 3.73 no problem.
I know of a 68 L78 with 3.55 and M22.
Re: Muncie
« Reply #3 on: January 20, 2022, 01:15:44 AM »
If not mistaken there is a 68 L78 with M22 and a 3.08 or a 2.73.
Re: Muncie
« Reply #4 on: January 23, 2022, 01:28:28 AM »
Yes two with 3.07 - very unusual that they would be ordered that way.
Re: Muncie
« Reply #5 on: January 23, 2022, 02:17:43 PM »
I agree, it had to have been a slug from a standing start... and the top end would have been way faster than I would want to go, especially given the tire tech
Re: Muncie
« Reply #6 on: January 23, 2022, 04:05:23 PM »
3.08 gear in a Firebird/TA with a 27 inch tire gets light in the front at 5500. And it’s a little over 140.
“'Cause if I had a set of wings, man I know she could fly“
Run it too long and a 400 Pontiac won’t have enough oil drain back from the top end. The crank main bearings get starved. Don’t ask how I know. Found out there is a way to fix that problem though.
