Author Topic: engine code  (Read 14649 times)
GIBSTER
engine code
« on: April 13, 2007, 02:59:27 AM »
On the front pad of one of my engines it has  V0327HN with a vin of 19lo49561. My questions are what was the  Engine Application Suffix Code HN used for ?  and any guesses on the partial vin (what vehicle)
                                                         Thanks Darryl
zzmike
Re: engine code
« Reply #1 on: April 13, 2007, 03:12:00 AM »
I have HN as being as being a 300 HP (4bbl) 350 with a TH-350 out of a fullsize car.  No guesses on the car, other than it is a 1969 Chevrolet built in LA.  Maybe others will have more info???
« Last Edit: April 13, 2007, 03:18:38 AM by zzmike »
1968 Crossram Z/28 Camaro
GIBSTER
Re: engine code
« Reply #2 on: April 13, 2007, 03:18:06 AM »
Here are all the numbers  Front pad 19l049561  vo327hn ,  on the backside of the block drivers side 12 gm, and 3956618 ,and on the pass side c259, and in the middle behind the distributer a number 3
dab67
  • 67 SS
Re: engine code
« Reply #3 on: April 13, 2007, 09:55:59 AM »
3956618 block used on 68-69  A,F and Corvette 4 bolt, 69 302 Z28 4 bolt, 69 327 Fullsize car 2 bolt and 69 350 cars 2 and 4 bolt.
C259  block cast on march 25 1969
V0327HN  Engine build date at Flint on March 27, 1969, HN could be either 327 full size or 69 350/300 hp 4 bolt full size.
I noticed also the the HN suffix code was used in 65 for the Corvette. (Nastyz28.com)
Dave
Re: engine code
« Reply #4 on: April 13, 2007, 08:34:33 PM »
Dave
"HN" was used on the '65 Corvette, but only with a 3782870 block.
zzmike
Re: engine code
« Reply #5 on: April 13, 2007, 11:23:04 PM »
The 3956618 was available as a two-bolt or 4 bolt 300 hp version of the 350 V-8.   There is no record of the HN suffix being used in a 327 3956618 block that I can find reference to.
GIBSTER
Re: engine code
« Reply #6 on: April 14, 2007, 02:17:05 AM »
Is there any way to track the type of car by that partial vin?
Mark
Re: engine code
« Reply #7 on: April 14, 2007, 04:32:42 PM »
Whatever it is, 350 or 327 it didn't originally come out of a Camaro.  No 327s in a Camaro after 1/1/69.  This engine came out of an Impala, or Chevrolet (full sized) assembled at the LA plant.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
