Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Big block clutch adjusting rod and swivel
« previous
next »
Print
Pages: [
1
Author
Topic: Big block clutch adjusting rod and swivel (Read 3366 times)
john302
Member
on:
December 15, 2021, 09:52:14 PM »
Does anyone know the gm part number for the threaded clutch adjusting rod and swivel for a 67-69 big block four speed ? thanks
Tweet
Logged
Hero Member
caretaker of 1971 LT1's 11130 & 21783
Re: Big block clutch adjusting rod and swivel
Reply #1 on:
December 15, 2021, 11:39:39 PM »
Don't know the part number but big blocks use a threaded tube and rod not the swivel block and rod.
Logged
Hero Member
Reply #2 on:
December 16, 2021, 12:26:50 AM »
Per view A - Items 3 and 4 (and the production nut) in the attached. (P/N 9779202 and P/N 3840845)
Logged
Hero Member
Reply #3 on:
December 16, 2021, 07:54:48 AM »
My fault apparently 67-68 is different
69 used the tube and rod.
Logged
Hero Member
Reply #4 on:
December 16, 2021, 02:20:41 PM »
No, all three years used the same linkage. (See the 1969 AIM sheet attached)
As a matter of fact, this same arrangement was used on Buick's, Oldsmobile's, Pontiac's, trucks, and other Chevrolet and GM years and models.
Logged
Hero Member
Reply #5 on:
December 16, 2021, 07:22:21 PM »
The originals with Bergy's L78 pacer are the tube and the rod- he doesn't have a Small block V8 Camaro so now I can't figure out which one.
I had to weld up the worn stud pin and file it back round.
Logged
Hero Member
Reply #6 on:
December 16, 2021, 07:30:54 PM »
The small blocks used what you show in your drawing above (#17 and #18), but the big blocks used what I posted before. HOWEVER. (and this is a BIG however), If you're running headers on a big block, the original setup will hit the header tubes when you engage the clutch. You either have to fab up something that'll clear the header tubes or you can use the small block arrangement, which is what I'm using with the Hooker headers I have.
Logged
Hero Member
Reply #7 on:
December 16, 2021, 07:35:27 PM »
Thanks, perhaps that is the explanation.
Logged
john302
Member
Reply #8 on:
December 17, 2021, 03:32:22 PM »
yes it is the rod and swivel for a big block . thanks
Logged
Print
Pages: [
1
« previous
next »
General Discussion
