Author Topic: DZ suffix ?  (Read 5208 times)
john jay 69Z
DZ suffix ?
« on: December 12, 2021, 04:51:37 AM »
Hi, I am looking at the Meccum Kissimmee Auction in January 2022 and seen a Daytona Yellow Z28 Lot R176 for Thursday 01/13/22 !  https://www.mecum.com/lots/FL0122-486940/1969-chevrolet-camaro-z28/
its engine suffix is V0820DZ although from the 8 onwards the font size is larger than the others is that normal? the car is built 09/22/69 which would make it 09D are the dates ok?
I looked at my engine and it is V0902DZ and built 09/15/69, any insight as to Lot R176 being ok
Thank you again for any input
John
« Last Edit: December 12, 2021, 05:23:32 AM by john jay 69Z »
Re: DZ suffix ?
« Reply #1 on: December 12, 2021, 02:44:01 PM »
Although the 'pad' isn't totally to my satisfaction, it's possible that the 'apparent' larger size fonts as the stamp goes to the right is due to the 'angle' of the photograph along with the lens used on his camera.  It's curious enough that I'd want to look a little closer though... and examine the cast date on the block, etc...
Re: DZ suffix ?
« Reply #2 on: December 12, 2021, 06:50:49 PM »
My grandson who isn’t quite 6 yet could take better pics of the drivetrain stampings. :(
Re: DZ suffix ?
« Reply #3 on: December 12, 2021, 06:52:41 PM »
I believe  your suspicions are correct - the DZ is definitely larger that the previous date code characters. look at the bottom of the "D" in relation to the previous character - obviously slightly larger. I can't say it's incorrect, but it would bear a closer examination.
Nice car, but why would you spend all of that time and money in a restoration like this, and then put the wrong shifter in it ? If you wanted to get away from a wobbly slip fit cushion, buy the reproduction bolt on with the correct round handle -
Re: DZ suffix ?
« Reply #4 on: December 12, 2021, 11:58:46 PM »
I think the angle of the engine pad picture is terrible. It might be OK, I can’t tell based on that crappy photo.
Danzo
Re: DZ suffix ?
« Reply #5 on: December 13, 2021, 01:09:36 AM »
Brought it here to view. It looks like there is a Z or a 7? (faint) after the enlarged Z
Doc.
Re: DZ suffix ?
« Reply #6 on: December 13, 2021, 07:20:56 AM »
It is a "DZ" Danzo. it is just the way it was stamped. I have seen many where the bottom of the Z is very light
Jonesy
  • 1969 Camaro z28
Re: DZ suffix ?
« Reply #7 on: December 13, 2021, 03:37:20 PM »
I think its the angle of the pic that makes the fonts get larger at the end. I think its a good stamping
1969 Z28 Azure Turquoise
dannystarr
Re: DZ suffix ?
« Reply #8 on: December 13, 2021, 04:30:32 PM »
Hard to tell, but sure looks like the last 4 digits are bigger to me. And is that the top of the original Z stamp? And the Z also looks lower?... Danny
dannystarr
Re: DZ suffix ?
« Reply #9 on: December 13, 2021, 04:33:23 PM »
one more
Re: DZ suffix ?
« Reply #10 on: December 13, 2021, 04:34:46 PM »
It is real.
dannystarr
Re: DZ suffix ?
« Reply #11 on: December 13, 2021, 06:50:48 PM »
WOW.. OK, so did they find a block, deck it and rent the gang holder and stamp it? Never seen a jumped double stamp travel that far when striked, I mean struck. Need block casting number and casting date to help.
Someone request that info. ... Danny
Re: DZ suffix ?
« Reply #12 on: December 13, 2021, 08:22:42 PM »
Agreed, it's the angle. Pad is OK.
jcabuilder
Re: DZ suffix ?
« Reply #13 on: December 16, 2021, 12:42:09 AM »
Looks like a nice car and I think it will get a buyer within that price range.
1969 Z28 X33 Tuxedo Black
2007 BMW Z4 Sapphire Black Metallic
2016 Ford F150 King Ranch Shadow Black
