Author Topic: Rally Wheel Paint  (Read 4487 times)
jmcbeth
  • 1st and 5th Gen Camaros
Rally Wheel Paint
« on: December 04, 2021, 01:53:39 PM »
Restoring my original YH wheels. Looks like the wheel was dipped in semigloss black, then the front of the wheel was painted with the Argent silver, hence the over spray often seen on the back side of the wheel. Can anyone confirm this?
John
1969 Camaro Z/28 RS
Numbers Matching
Re: Rally Wheel Paint
« Reply #1 on: December 04, 2021, 02:33:01 PM »
http://www.camaros.org/assemblyprocess.shtml
Sheet Metal Painting: All raw parts (wheels, brackets, etc.) and the front end sheet metal (hoods, fenders, lower fender extensions, header panels, front valances, radiator supports, inner fenders, etc.) went through a cleaning, degreasing, and hot phosphate system, then through a flow-coat booth where it was deluged with black primer from all directions and then baked.
Wheel Painting: The wheels were removed from the prime conveyor and placed in another conveyor system that took them through a booth where their faces were sprayed with color wheel enamel, then through an oven, and the conveyor continued to the wheel & tire assembly area where the wheels were picked off.
« Reply #2 on: December 04, 2021, 02:38:38 PM »
From what I read on the site, yes.
From my own wheels, yup.
Runs are obvious on the front, with actually just a thin coat of silver. Yup, overspray on the rear.
Just did mine a few weeks ago, if I haven't already, I'll post.
Came out great, but not pulling a muscle patting myself on the back, lol. Wheels vgc, cleaned, scuffed, LITE coat of paint, had about two hours into them.
« Reply #3 on: December 05, 2021, 03:20:32 AM »
Hi John, hope all is well.... info supplied and your analysis dead on.  Note, overspray on many survivor wheels I’ve reviewed is on the light side so I deliberately complete the overspray thru the wheels windows and then block off and finish argent silver.
jmcbeth
« Reply #4 on: December 05, 2021, 03:22:44 PM »
All,
Thanks for this info. Very helpfui!
William, what was the purpose of the phosphating before priming? Is this for paint bonding or rust protection or both?
Chick, Nice to hear from you! I appreciate the tip to do a light overspray through the windows, then block off for spraying the front.
John
1969 Camaro Z/28 RS
Numbers Matching
« Reply #5 on: December 05, 2021, 04:39:31 PM »
Both according to google.
usa1ti
« Reply #6 on: December 06, 2021, 01:42:10 PM »
My spare had been painted but the 4 YH's on the car were original paint. The wheel back looks as described above.
Todd, East TN
Jonesy
  • 1969 Camaro z28
« Reply #7 on: December 06, 2021, 07:13:10 PM »
Heres the back side of my original spare YH rally wheel on my Van Nuys 02A z28
1969 Z28 Azure Turquoise
« Reply #8 on: December 06, 2021, 07:50:47 PM »
Is the article by JohnZ on the process for wheel receiving, prep, paint, etc on the CRG site? (I know there is a breakdown in the Assembly process A-Z written by him)
Was the single page article (with the reference to the painting fixture with 5 tapered spindles for the set of wheels) only on the NCRS site?
« Reply #9 on: December 12, 2021, 08:55:28 PM »
